2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Manual transmission fluids
      03-04-2020, 02:11 PM   #1
stlb5
stlb5's Avatar
217
Drives: '19 M2C MT, '15 X5 Msport
I'm looking to use Red Line products and I'm a bit confused. ECS Tuning and TCP Euro both recommend MTL 75w80. Red Line recommends DCTF Dual Clutch Transmission Fluid. I don't consider Amazon the expert, but they say neither will work. From searching on here, I've found a few different answers as well. Does anyone have a solid answer?
2019 M2 Comp, MT, BSM
2015 X5 Msport, CB (Hers)
2014 M235i MT, BSM, MPE, Dinan Springs (Sold)
      03-04-2020, 06:42 PM   #2
4Hockey4
Drives: Pinto
BMW service said use 90, but 85 is fine. 110 is overkill.
      03-04-2020, 07:50 PM   #3
pmcmtnbkr
pmcmtnbkr's Avatar
106
Drives: BMW M235I
they both will work depending on if you have a Manual transmission or an auto trans. the MTL 75w80 is for a manual trans and has additives to protect the brass syncros while the DCTF is used in Automatic transmissions. If you are looking to change the diff fluid you can use redline 75w80 it safe for the spider gears/ LSD but is to slick to use in the MT and dose not have additives to protect the brass.
      03-04-2020, 08:01 PM   #4
stlb5
stlb5's Avatar
217
they both will work depending on if you have a Manual transmission or an auto trans. the MTL 75w80 is for a manual trans and has additives to protect the brass syncros while the DCTF is used in Automatic transmissions. If you are looking to change the diff fluid u can use redline 75w80 it safe for the spider gears/ LSD but is to slick to use in the MT and dose not have additives to protect the brass. A simple search of redlines product site when entering in your car info will provide all recommended fluids that redline makes
That's what didn't make sense. Redline's site recommended the dctf for my manual transmission.
      03-04-2020, 08:10 PM   #5
pmcmtnbkr
pmcmtnbkr's Avatar
106
Drives: BMW M235I
very interesting i just ran the search of their site and it did the same thing they must have a bad link the other week it crossed to the MT 75w80 when i checked it.
      03-04-2020, 08:11 PM   #6
John in VA
Drives: 2015 228i M Sport
I've used their D4 ATF in my E46 & newer manual transmissions.
https://www.redlineoil.com/d4-atf
      03-04-2020, 08:17 PM   #7
pmcmtnbkr
pmcmtnbkr's Avatar
106
Drives: BMW M235I
interesting they also recommend https://www.redlineoil.com/mtl-75w80-gl-4-gear-oil
      03-05-2020, 05:21 PM   #8
John in VA
I've used MTL in the 2002s, E28s & E30, but went with their recommendation of D4 for the "newer" transmissions. It can be awfully confusing/complicated!
      03-06-2020, 08:09 AM   #9
K8_M235i
K8_M235i's Avatar
Drives: CM E36
I also use D4. It was recommended to me by a close friend who owns a bmw race shop. They use d4 in all street cars and mtl in all race cars.
2015 F80 M3 DCT, Carbon Roof
1998 S54 E36 M3 BMWCCA Club Racing #532 CM
1995 E36 M3 Sunbelt S52
      03-06-2020, 09:41 AM   #10
jwmuscat
http://www.pentosin.net/specsheets/T...2017_COLOR.pdf
Recommended for newest bmw manual transmission fluid the lt5. Apparently this is the one fluid.
      03-06-2020, 09:48 AM   #11
stlb5
stlb5's Avatar
217
Interesting. Guess the Red Line DCTF makes a bit more sense now.
      03-10-2020, 10:47 PM   #12
kthor703
Drives: 2021 M2 Competition
Feel free to call redline up if you want to clarify about the ATF verse MTL. I called them to ask questions about diff oil and found them very helpful.
      04-30-2020, 02:04 PM   #13
4Hockey4
Drives: Pinto
Spoke with Dave at Redline, little difference between DT4 and DCTF. I'm running the Lt5 equivalent, since I'm under CPO still.
He'd lean DT4 in much colder situations.
Silly how much cheaper than BMW shop
