03-15-2018, 01:06 PM | #23 |
Rep 15
Here are a pair of pictures showing the rear mudflap before it was reshaped and after final fitting. As received the flap had a wedge shaped gap between it and the bottom pan of the car. I had to use a hot air gun to reshape the flared section so that it went up and reached the bottom pan. It took a few tries but the plastic shapes easily with a little heat. Not much spring back. Both sides had the same issues and came out equally well fitted.
mdputnam288.50 |
03-15-2018, 01:08 PM | #24 |
Rep 15
Still struggling with the picture posting thing
03-15-2018, 01:16 PM | #25 |
Rep 15
Rear mudflap gap before reshaping
Here you can see that the rear mudflap was really intended for a fender that had a body fold line in it that is not present on my 2018 230i MSport. An earlier picture that I posted shows that the gap could be closed up by heating up the mud flap with a hot air gun and reshaping it. If the plastic gets shiny, you put too much heat on too fast. Keep the gun away a few inches and be patient. You need to soften the plastic all of the way through its thickness before it will take a set.
03-15-2018, 01:31 PM | #26 |
Rep 15
Front Mudflap Modifications
The front mudflaps did not need any heat forming, but they did need some whittling. The original profile had a bulbous protuberance that was meant to engage a hollow in the inner fender well but my inner fender wells didn't have this so I had to carve away the extra material. A box cutter did the job easily.
03-15-2018, 05:00 PM | #27 |
Rep 103
08-06-2020, 02:08 PM | #29 | |
Rep 1,450
What part numbers are these? Will they fit an M240i ?
M240i LCI (Mineral Grey):- M2 Door Mirrors, M2 Black Kidney Grills, Lower grille inserts, MP Exhaust, Dinan Carbon Fibre CAI, hot climate intake elbow
08-06-2020, 02:21 PM | #30 |
Rep 736
Drives: Lexus RC F
I just got an email back from Tommy, he said he needs someone with an F22 to meet up with him in Woodbridge, NJ so he can design a template.
If you want to be the test mule please email him, got6speed@gmail.com
Estoril Blue E36M3
