11-03-2019, 10:33 PM | #288 | |
Supreme Allied Commander
3837
Rep 54,339
Drives: F80 M3
https://www.hpashop.com/Hawk-Perform...ds-Hawk-50.htm |
11-05-2019, 11:21 AM | #289 |
Rep 445
Just bought some Akebono Eur1880's as I have been having trouble with my Powerstop z23 set in the front and particularly them shifting forwards and backwards and making a very loud clunk on the drivers side. I have had this sometimes with the OEM set, but not to this frequency or intensity. I will report back when I get those in the mail and install them. Only going the front for now, if these work well I will probably replace the powerstops back there too.
11-05-2019, 12:03 PM | #290 | |
3837
Rep 54,339
Drives: F80 M3
11-05-2019, 01:40 PM | #291 |
Rep 445
Yep, it has them. This really got worse when I changed rotors and endlinks, so Im not really convinced this will solve it, but its worth a shot to me.
02-27-2020, 02:46 PM | #292 |
Rep 1,931
bump to keep on 1st page.
www.nybmwcca.org
03-12-2020, 11:03 AM | #293 |
Rep 1
Thanks much everyone for all the good info - glad I read this before buying pads! Just ordered a set of EBC Yellows for my 235, it's my commuter car/weekend canyon carver so looking forward to a little more braking power in the tight twisties we have here in the mountains. Will report back once I have a chance to get them installed...thanks again!
04-19-2020, 09:14 AM | #295 |
Rep 1,931
Do not use red stuff, you want yellow.
www.nybmwcca.org
04-19-2020, 12:34 PM | #296 |
Rep 674
Read most of the thread, and didn't see alot on daily/street squeak. Shop is rec'ing ShopTech for street and light track, few folks here say less dust, better pad.
Anyone using StopTech have any issues with street noise and is dust less ? My stock pads are horrible for dust Thanks |
04-19-2020, 01:13 PM | #297 | |
Rep 3,495
04-19-2020, 02:35 PM | #298 |
Rep 2,873
I think anything that gives you better (or even passable) track performance will dust up more than a factory pad, not less. If you think of factory pads as horrible, you probably want to run ceramics on the street and then swap out for s/t better when you go to the track.
06-05-2020, 03:27 PM | #299 |
Rep 674
Do brake sensors work with Ferodo DS2500 and/or do I need to order new ones ? Front pads under 1/3 left, backs have over 1/2 left (is that normal wear ?) may just add fronts for now when they add Motul
Is it ok if they dont work with sensors if checking often ? (code etc) Also with light track days, and ok temps in southern VA, can I run the Motul 660 year round ? and just change out a bit more often ? (I won't be changing out pads/fluids etc myself, but looking for bit better performance on light track days) THx |
06-05-2020, 05:53 PM | #300 |
Rep 3,495
06-05-2020, 06:46 PM | #302 | |
Rep 3,495
Track attack - are you saying you'll drive a total of one hour per day or per event? Is the hour all at once, or is it broken into sessions; if the latter, how long are the sessions? More importantly, what are the braking zones like (e.g., 145 --> 60, 90 -->35, 125 -->75). I realize you may not know yet. I don't think there's anything 'light' about an HPDE. I've run my car almost exclusively on a handling track that has a single heavy-braking zone, and the braking components get extremely hot (as measured with brake temp paint on the rotors and caliper temp strips on the outside of the calipers). Why? 'Cause our cars have quite a bit of power and they are heavy. If you do an HPDE, which track will you be running on?
06-05-2020, 08:39 PM | #303 |
Rep 674
light was more in terms of how often, not always how HARD I'd run. Its gonna be a garage queen, drive some to work (not too often) and occ. track.
Just keep working towards small improvements, lil more HP(downpipe helped), better tires(PS4S next) and brakes/fluids, bushings. Probably wont get into camber plates or LCA etc. I may look into StopTech lines. Gonna work towards something that improves the performance, and since I won't be switching any of this out (except fluids), I can keep on for DD. First one was Dominion, but could do VIR and Summit eventually. Dominion has tight corners but not too heavy speeds into each, but enough. Last edited by 4Hockey4; 06-05-2020 at 08:46 PM.. |
06-05-2020, 10:09 PM | #304 | |
Rep 3,495
2) My 2¢, of course, but our cars don't need more power unless you're taking them to the strip. What they need is more handling via negative camber and anything else that will enable them to turn more quickly. They need more tire, but that's only if you're prepared to change to a more aggressive street compound or manage two sets of tires. They need more heat capacity in the brakes. They also need more brake pad, but those pads need to be reasonably well-matched to the tire you're running. 2a) Most of all, what our cars need is a limited slip differential. Otherwise, we'll always be operating with a significant handicap. 3a) Don't know Dominion. 3b) VIR: big-boy track, a la the Glen and Mosport, major fun, get all the qualified instruction you can. 3c) Summit Main: a handling track, yeah, but the most fun handling track I've ever been on. I like that track! Videos here: in the dry, with data – https://youtu.be/XfOHPoEH2Yk; in the wet, showing different lines through the Carousel – https://youtu.be/xC6FgRUAjag. 3c1) Summit Jefferson: haven't been on it, but from what I've seen it's very much a handling track - one very well-suited to lightweight handling cars like the Miata and the BRZ. That's not a bad thing, but with nearly two tons to sling around, it's not at all ideal for our cars, which are designed for tracks that let them stretch their legs. Think: VIR, the Glen, Road Atlanta, etc.
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF Last edited by dradernh; 06-06-2020 at 05:19 PM.. |
06-06-2020, 12:42 PM | #306 | |
Rep 2,873
If you aren't going to track often, you may want to just stick with stock fluid - it is nearly as good for heat range, and it ensures that if you have brake issues, they will be the kind that recover with a cooling lap (or a few corners). With the Motul, you need to change it often enough that you can swap back to factory for winter anyway (wouldn't want to run Motul for a full year, and it isn't 'low viscosity' for winter in the ABS). This swap is what I do each spring and fall. |
06-06-2020, 08:04 PM | #307 |
Rep 674
thx for thoughts, think I'll play at Dominion for now. Getting PS4S and better pads, probably DS2500, decide on Motul later, better bushings. If I was going to go LCA, wheels, camber plates, LSD to 235i, (I can't install) M2 would have been as cheap lol. Its a "drive when I feel like it" but dont want to dump $8k+ into for a few times at track each year.
Here's decent vid of Dominion (not me) tight narrow track, 2.0 miles long. about 30 minutes north of Richmond VA. Last edited by 4Hockey4; 06-06-2020 at 08:10 PM.. |
06-07-2020, 11:27 AM | #308 |
Rep 442
