2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Resonator deletes
      05-25-2020, 01:57 AM   #1
TonM3
TonM3's Avatar
Drives: 2006 E46 M3 / 2017 M240
Resonator deletes
Dinan makes a 2 resonator delete for the m240. At $500 it is not particularly expensive, except it is just a pipe.
Several people have talked about just having a muffler shop cut out the resonators. does anybody have pictures of how this was done, the diameters of the pipes involved?
I've swapped out axle back exhaust before, not difficult. Sitting at home while on quarantine I'm thinking of doing the resonator delete myself with clamps but it would be helpful to know the diameters and to confirm the pipes are round where I would cut them.
I could build a space shuttle with the right YouTube video, but I can't seem to find one for this.
E46 -> E90 -> F30 -> F23
      05-25-2020, 10:19 AM   #2
Mark.h
Drives: 2015 bmw m235i
Oem exhaust size is 80mm most common piping available at local shops etc will be 3" which should be able slide inside of the 80mm oem piping. 80mm comes out to 3 and 1/8". Had it done at a muffler shop and they charged me $80.
      05-25-2020, 12:48 PM   #3
TonM3
TonM3's Avatar
That's exactly what I was looking for, thanks.
I thought there were 2 resonators though.
      05-25-2020, 12:51 PM   #4
Mark.h
Sorry just saw you have a 240. Picture is of a 235. Exhaust diameter is the same but not sure on if piping is circle or flattened on both resonators. For 235 it is perfect circle if you cut right at the ends of the resonator. My guess would be that both resonators on the 240 would be the same way.
      05-25-2020, 03:45 PM   #5
TonM3
TonM3's Avatar
I found this from an older post. One resonator is on a round pipe one is oval
https://www.2addicts.com/forums/show....php?t=1352934
      05-25-2020, 03:50 PM   #6
peediR
Drives: Estoril Blue M240i
2018 BMW M240i  [0.00]
Hey TonM3
I have a m240i and got both resonators deleted. The shop I went to made a single pipe that replaced both resonators.
      05-25-2020, 04:04 PM   #7
TonM3
TonM3's Avatar
Originally Posted by peediR View Post
Hey TonM3
That is cleaner. Thanks for the suggestion.
      05-26-2020, 04:35 PM   #8
Liandri
Liandri's Avatar
Drives: 2016 M235i
Just a heads up you posted this in the n55 forum, there's a b58 m240i specific forum this would better belong in
