2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Compact spare tire kit?
      05-24-2020, 10:48 PM   #23
grocerylist
Drives: BMW M235i
2016 BMW M235i  [0.00]
Originally Posted by AleksanderSuave View Post
At that price you could buy an oem refinished wheel to match yours, a brand new tire, and a jack and breaker bar, and not have to worry about fitment ever.
What’s the added benefit? Minimal saved space?
You get a matching wheel and have the benefit of if you ever curb one, just swap it out, and a full size tire will take you as far as you need to go. I’ve had days of waiting on a new tire in this size to come in. Why risk it?
That's a good point. I've got staggered wheels so I'd just have to make sure the fronts would also fit the rears (probably not a problem). A new full size wheel and tire might be ~ $450-500.
      05-25-2020, 09:19 AM   #24
cooolone2
cooolone2's Avatar
625
Originally Posted by GrimJaw View Post
Wait, I've never really needed to use spacers on past cars. Don't spacers need to be installed with a special ring/need to be stuck on?
Hub Centric rings are only required when the wheel and hub flange size are mismatched. Is for ensuring the whell is centered. Honestly, this is not totally necessary as if you install the wheel correctly, or, snug each bolt one at a time, cross pattern, and THEN tighten, you'll be centered.
Anyways...
Originally Posted by cristo View Post
The 2 series compact spare kit from
bimmerzone fits our 2020 f23 M240i
front and back (blue M calipers and rotors)
without spacers. I tested the fit and it
works.
The compact spare for my 2009 JCW r55
MINI Clubman needs a 12mm spacer to
clear the rear JCW brakes, but the
tire/wheel/jack/tool tray fits nicely out
of the way in the spare well.
On the other hand, the compact spare/etc.
strapped to the floor of the trunk of the
M240i convertible does take up up a bit
of real estate.
Awesome! Thanks for the information
      05-25-2020, 12:22 PM   #25
AleksanderSuave
Drives: 2017 M240iX Coupe
Im pricing it out, you can get a refinished wheel and new tire for about $380. Less if you want to go used.
then you just need someone to mount the rubber on the wheel. runs about $20 around here locally.
      05-25-2020, 02:35 PM   #26
H2O_Doc
H2O_Doc's Avatar
Drives: BMW M2C, GLB-250, C7 Z51
Another possible option is the hemorrhoid donut spare tire option (I hear it corners well):
Vive Inflatable Tailbone Cushion - Hemorrhoid Pillow Donut for Pregnancy, Piles, Coccyx Pain Relief - Orthopedic Treatment Doughnut Seat - Ring Chair Pad for Prostate, Sciatica - Inflate Assist Valve https://www.amazon.com/dp/B07146JPWL..._C2bZEb9DST5P9
Serves multiple purposes.
      05-26-2020, 02:28 AM   #27
Oldbay
Oldbay's Avatar
31
Drives: M240IC 6MT RWD
works.
of real estate.
I have the Bimmerzone in my M240 convertible. It does take up some space, but I've not had any major issues with it. It's a minor inconvenience. But, I prefer to have it back there for all of the east coast potholes. Had one of my BMWs towed by AAA once and won't make that mistake again. I think AAA and BMW both use the same regional tow-trucks. I know for a fact that AAA and Audi use the same network. Around the DC area they aren't too good. I like to keep it back there just in case:-)
GrimJaw105.50
      07-05-2020, 04:39 PM   #28
drives like jehu
Drives: BMW M235i
Used the E90 set up with spacers
See my ad in the wheels/tires section if you want to buy my old one.
I got the recommended setup for the E90; when I tried it on the F22 it scraped the rear brake caliper (duh).
Adding 2x 5mm spacers and extended lug bolts and it works.
Never would go too far on a doughnut like this, but beats waiting for hours for a flatbed.
      07-05-2020, 06:05 PM   #29
davehoff
Drives: 2018m240ix convertible
Took my run flats off my F23 bought a sealant
Compressor kit from Griots unless it's a
Side wall blowout should be good enough to get
Home or to a tire shop the F23 has a small trunk to begin with a spare would eliminate it
I've had 3 flats in 30 years
One run flat blowout from a pothole and 2
From screws which were repaired
      07-15-2020, 10:52 AM   #30
M Smurf
M Smurf's Avatar
157
Drives: 2013 328i M Sport
I have almost the same setup. Tire plug kit
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Plus a Slime Compressor
