05-18-2020, 12:30 PM | #1 |
Rep 11
Small Leak
Hi everyone.
First post. I'm hoping for a little help with this. I have a small leak coming from the front driver's side of a 2015 f23. It is almost in front of the wheel. The fluid seems to have a green tint to it which made me think it was coolant but it is greasy to the touch. I looked around and didn't notice anything glaring. I did set an appointment with a local mechanic but wanted to check with everyone here to see if anyone has experienced anything like this. FYI. No mods outside of wheels. Thanks. |
05-18-2020, 02:05 PM | #3 | |
3612
Rep 3,579
If you don't have documentation to prove what type of coolant is in there (factory fill is blue), best to get it flushed and replaced with the correct spec. One policy I have when purchasing used BMWs in the past is to walk away if it doesn't have the correct coolant or service records showing the engine oil used at least meets BMW specs, as negligence in both areas is a pointer to other maintenance shortcuts. |
Nerf228x1.50 |
05-18-2020, 04:42 PM | #4 |
Rep 11
05-18-2020, 04:44 PM | #5 | ||
Rep 11
The coolant was green when I bought it two years ago. |
05-18-2020, 05:02 PM | #6 | |||
Rep 1,268
Take a look at this thread; of course his case is quite different than yours since he doesn't report a greenish hue to the leaked drops. https://www.2addicts.com/forums/show....php?t=1717018 |
05-18-2020, 09:02 PM | #7 | ||||
Rep 11
Thanks for your help. |
05-18-2020, 09:16 PM | #8 | |||||
Rep 1,268
Man, axle boots... In any case please update this thread after seeing your mechanic. I am very curious. |
05-21-2020, 11:51 AM | #10 |
Rep 1,268
Thank you for the update! Seems like your case was no different than the other thread I posted. People zeroed in on control arm bushings in that thread as well.
05-21-2020, 11:55 AM | #11 | |
Rep 11
Thank you. |
05-21-2020, 01:36 PM | #13 | |
Rep 11
I'll let you know more when I get the car back this afternoon. |
