2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes Rear shock mounts
      03-06-2020, 09:59 AM   #1
WolfGTI
WolfGTI's Avatar
2002 MINI Cooper S  [0.00]
2015 BMW X1  [0.00]
Rear shock mounts
I know Turner has the monoball upper rear shock mounts. That may be a harsh for daily use. I was also looking to see if the F87 rear shock mounts would work on the the F22 -Part numbers are totally different. Any thoughts ?
F87 https://www.ecstuning.com/b-genuine-...t/33502284703/
https://www.ecstuning.com/b-genuine-...h/33506862725/
      03-08-2020, 04:50 AM   #2
NISFAN
NISFAN's Avatar
United Kingdom
3489
Drives: BMW M2
They are different only because the shaft diameter of M car dampers is larger. The actual mount is the same.
What are you trying to achieve?
Monoball laying horizontally as a damper support is not the correct use of monoball. Any engineer doing this should be barred from working as an engineer, as they clearly don't make the grade.
