09-13-2018, 08:56 AM | #68 |
Rep 350
Did anyone encounter a problem where you can't fully insert the two forward-most plastic rivets on both sides because there is the metal frame very close behind the plastic body work?
09-13-2018, 10:52 AM | #69 |
Rep 5,369
There are shorter rivets for those points.
wntrsnowg105.50 |
09-13-2018, 10:54 PM | #71 |
Rep 350
Thanks for the advice. I picked up some 3/8" aluminum rivets and was able to do the two front most locations with them.
2016 m235i RWD 8spd 2016 Mazda CX-5 Past - B6 Audi A4 |
05-15-2020, 05:08 PM | #72 |
Rep 3
Hi guys, great install thread, I can see still providing value after 4 years.
I bought the side blades and took both out the boxes..... now I cant tell which one goes on which side? ) they both seem to line up.... please help One end of the blade has an extra piece of 3M about 2 inches long... does that go at the front or the rear of the car when attaching? |
01-02-2021, 05:38 PM | #73 |
Rep 45
Thanks to DrPooManchu. I took a simpler route. DrPoo - I appreciate your meticulous method. What I did was to clean the install area with Griots carwash soap, then again with Griots spray on carwash untill there was no dirt, tar, etc. Then, I used 3M adhesive promoter ( Amazon : #M Adhesive Promoter 4298 pack of 5 for about $15). I used 2 promoter wipes on each side. Then I dry fit a blade. I removed the double sided tape then put the blade in place. I did this by myself, no issues. The tape adheres almost instantly, no blue tape needed. It cured very hard in 45 minutes. Then I drilled and installed the pop rivets. 2 hours by myself. I left the blades matte black on my Glacier Silver 2017 Vert. The Front and rear spoilers, Read M diffuser and all reflectors are painted Glacier silver also. I think the blades look good black, coordinating with the M Perf rocker decal. I really doubt the plastic rivets are needed though, the tape is very impressive!
2017 M240i Vert Glacier Silver, Red Leather, Front lip, Trunk spoiler, Painted reflectors, Door Projectors, MP mats, CCA badge, Dinan Stage 1, Dinan CAI, M Perf Exhaust.
