2Addicts | BMW 2-Series forum Technical Topics Cosmetic and Lighting Modifications Side Skirts Blades
      05-15-2016, 05:33 PM   #23
Michall
Drives: 15 M235i
Originally Posted by Drpoomanchu View Post
I dont have any intentions of painting these parts. I will leave them in their current state.. I would gladly post pics ater install
I'm waiting patiently.
      05-15-2016, 10:47 PM   #24
MASHCT
MASHCT's Avatar
Drives: 2017 BMW M2 MG
+1 + Infinity
Rear diffuser $360 and blades were $105 a piece so $210... Just recvd mine today took 2 days... Very quick and Brian is a class act..!
2017 M2 | MGM | 6SPD Std | RWD | MP Exhaust | CSF FMIC | Active Autowerke DP w/ HF CAT | FTP Charge & Boost Pipes | Fortune Auto series 500 7k/14k coilovers | CDT Audio ES Gold Fronts & HD series Rear | Richland Forged Project Nurburg RF-GT4 Wheels | AudioControl LC-6.1200 | JL Audio TWK 88 | CF Goodies
      05-15-2016, 10:53 PM   #25
MASHCT
MASHCT's Avatar
The offsets are 35mm for all of the wheels & they're 18x8". They do not poke at all, no matter what else you might read about 18x8" & 35mm offsets. The rears push out about an extra 1/2"; they're just shy of the wheel well edge.
Yes, the OEM center caps do fit perfectly. But they wheels come with a plain black center cap. If you buy a 62-65mm BMW emblem and double-sided sticky tape, you can have a second set of BMW emblem center-caps.
The fronts push out a little farther, but are still tucked slightly inside the wheel well edge.
Since both wheels push out a little farther, the "wheel gap" also appears shorter. An added benefit if you want to lessen that gap but you're concerned about lowering the car.
And there is no rub. I sent you a PM on price & e-tailer.
Jim
Originally Posted by leeadam View Post
Different subject sorry, i would like to get a set of our alloys. what were offset, wonder if i can get in uk. Did the original bmw centre caps fit and the tyre valve sensors.
      05-16-2016, 09:05 AM   #26
OpenAir
OpenAir's Avatar
Drives: Enzo F23 228i
2015 BMW 228i  [0.00]
Originally Posted by MASH65 View Post
Here are pics of ones I had custom painted & installed myself. I will tell you this - they gather road dirt after riding around on wet roads. Put a couple of coats of good wax on them.
Pull the trigger - you'll be happy you did. These things add a great visual touch, for sure.
Just gotta say, that is a sharp looking ride!
      06-07-2016, 09:14 AM   #27
leeadam
leeadam's Avatar
United Kingdom
468
my blades on too now...
      05-15-2020, 06:08 PM   #28
blackm240i
Drives: M240i
Originally Posted by Joaco135 View Post
Got a new set of side skirts blades (splitters) and since I trew the boxes away, can't tell which is left or right. Already looked for part # on the splitters but it has none on either blades, Need help
Just did the same thing and threw the boxes away.....
One end of the side blade has a second piece of 3m about 2 inches long, does that go at the front or the rear of the car?
      05-16-2020, 09:44 PM   #29
Joaco135
Joaco135's Avatar
Drives: 2020 M2C LBB
Look at post #6 on this thread, that was what I used to get them right. I can't remmember if the extra 3m tape goes towards the front or back, after all it has been 4 years since got them installed, lol.
      05-18-2020, 03:42 AM   #30
blackm240i
Drives: M240i
I sorted it, thanks Joaco for the response, for those with the same issue in the future....
There is actually a LH (left hand) and RH (right hand) printed on each blade which tells you which is which.
