2Addicts | BMW 2-Series forum Technical Topics Cosmetic and Lighting Modifications Side Skirts Blades
      03-22-2016, 11:30 PM   #1
Joaco135
Joaco135's Avatar
Drives: 2020 M2C LBB
Side Skirts Blades
Got a new set of side skirts blades (splitters) and since I trew the boxes away, can't tell which is left or right. Already looked for part # on the splitters but it has none on either blades, Need help
      03-23-2016, 02:56 PM   #2
Joaco135
Joaco135's Avatar
Anyone?
      03-23-2016, 03:57 PM   #3
CanadianGatorBacon
CanadianGatorBacon's Avatar
Drives: M235i (holy crap!)
I don't think a lot of people have these, although I've been thinking about it. I haven't seen them in person, but does it matter? Are they contoured or shaped such that flipping them over changes them? Maybe some pics would help people figure out what's what.
Gone but not forgotten: 1992 Buick LeSaber Limited | 1999 Acura CL 3.0 | 2003 Volvo S60 2.4T | 2006 BMW x3 3.0i | 2009 Honda Fit Sport
      03-23-2016, 04:28 PM   #4
Uridian
Uridian's Avatar
42
Drives: E36 M3, 228i M Sport
How are they installed? Do they mount up with existing rocker panel mounting points? If so, it appears the mounting holes are not symmetrical front to back so you could compare the holes under the car to each blade.
This is a left rocker panel:
Note the gap in the mounting points as you approach the front of the car. Seems like that would correspond to the gap in the mounting holes of the side blade:
Might be worth crawling around beside your car a bit and just comparing parts to find out.
I've been considering those myself for a while... be sure and post some pictures once you're installed.
      03-23-2016, 10:41 PM   #5
Joaco135
Joaco135's Avatar
I have checked trying both blades on the same side and they appear to fit either one.
Uridian;
They mount via 3m tape that goes the entire length and in one of the ends it has an additional double sided tape that is about 2/3" long. After is installed by the tape then you have to drill little holes into the side skirt and use the plastic pop rivets that comes in the kit.
This week end will try to mount them or if anyone that already has them installed can post a pic from below showing one of the ends, front or back and what side then I can go from there...
      03-24-2016, 08:55 AM   #6
Rus.K
Drives: 2018 AW ZCP M3
I installed these 3 weeks ago, if you look very close you can see the blade is a bit thicker towards the front and gets thinner as you get closer to the back of the car. Also iirc the front of the blade, there is a small indent.
Also when installing, be VERY careful as the 3M tape is EXTREMELY strong and if you stick it on the car after using the adhesion promoter it is a pain to realign.
      03-24-2016, 11:27 AM   #7
Joaco135
Joaco135's Avatar
Rus,
Thanks for the help and advice on the tape, that is all I need it and should be installing them this weekend...
      04-05-2016, 06:41 AM   #8
CanadianGatorBacon
Ever get these on? Pics?
      04-05-2016, 10:02 AM   #9
Joaco135
Joaco135's Avatar
I did using Rus.K advice, will have pics later today.
      05-05-2016, 08:13 PM   #10
Drpoomanchu
Drpoomanchu's Avatar
Drives: AW M235i Man FBO
Any pics..? Thinking about pulling the trigger on these bad boys ..!
      05-06-2016, 10:33 PM   #11
MASHCT
MASHCT's Avatar
Drives: 2017 BMW M2 MG
Pic of painted side splitter bladess
Here are pics of ones I had custom painted & installed myself. I will tell you this - they gather road dirt after riding around on wet roads. Put a couple of coats of good wax on them.
Pull the trigger - you'll be happy you did. These things add a great visual touch, for sure.
2017 M2 | MGM | 6SPD Std | RWD | MP Exhaust | CSF FMIC | Active Autowerke DP w/ HF CAT | FTP Charge & Boost Pipes | Fortune Auto series 500 7k/14k coilovers | CDT Audio ES Gold Fronts & HD series Rear | Richland Forged Project Nurburg RF-GT4 Wheels | AudioControl LC-6.1200 | JL Audio TWK 88 | CF Goodies
      05-08-2016, 12:03 AM   #12
Drpoomanchu
thnx looks very nice. I am ordering the blades, MP diffuser and MP front lip this weekend. I like what you did with the front lip, do you have any better pics of the front end.? Did you do anything special with the rear diffuser?
      05-08-2016, 02:27 AM   #13
MASHCT
MASHCT's Avatar
Here are some pics I posted a little bit ago. The diffuser part of the rear balance is painted orange. The color is BMW's Valencia Orange. It is more orange than the reddish-orange you see in some of the pics. More like a slightly handle new(er) penny.
http://www.2addicts.com/forums/showthread.php?t=1253893
Jim
      05-08-2016, 02:30 AM   #14
MASHCT
MASHCT's Avatar
I just notice the orange part of the diffuser is barely noticeable. I will post another better pic once the sun comes out again here in CT. Been cloudy/rainy for over a week, very damned day!
      05-08-2016, 04:21 PM   #15
MASHCT
MASHCT's Avatar
More pics of the diffuser for you
Here you go!! Hope this gives you a good idea of how contrasting paint schemes look. The folks that did this for me came highly recommended. And let me tell ya - it's perfect. Straight lines, no over-spray - PERFECT.
(Just an FYI - no scratches on the bumper or diffuser. All reflections. I know how to wax a car. heh heh)
      05-08-2016, 09:40 PM   #16
Drpoomanchu
Looks great and very unique... Ive been tryin to figure out what i want to do if any accents. Thanks for posting the pics, very nice ..!
      05-08-2016, 10:57 PM   #17
kd0t
How much are the blades?
      05-08-2016, 11:27 PM   #18
MASHCT
MASHCT's Avatar
Price of the blades
Go to ebay & look up sunmotorsbmwparts (seller). Best prices for genuine BMW parts, including M Performance. (Example - I got the MP exhaust for $790; SS finishers for $170 for both.)
I don't recall how much the blades were because Brian @ sunmotors packaged them with the rear diffuser for $530 total & didn't show separate price. I'd probably guess $350 for the diffuser & $180 for the blades.
And it's free shipping. And they ship FAST FAST FAST, packaged very well.
Everyone in the general 2 series forums talks about sunmotors.
QUOTE=kd0t;19899812]How much are the blades?[/QUOTE]
      05-14-2016, 04:15 PM   #19
Drpoomanchu
Rear diffuser $360 and blades were $105 a piece so $210... Just recvd mine today took 2 days... Very quick and Brian is a class act..!
      05-14-2016, 05:08 PM   #20
Michall
Drives: 15 M235i
Are you going to paint them Alpine White or any other color? I'm very interested in buying them. It's a very subtle but nice addition. My car is also AW and if I buy them I'll paint them gloss black for sure.
Post some pics after you install them.
      05-15-2016, 10:45 AM   #21
Drpoomanchu
I dont have any intentions of painting these parts. I will leave them in their current state.. I would gladly post pics ater install
      05-15-2016, 02:20 PM   #22
leeadam
leeadam's Avatar
United Kingdom
468
Different subject sorry, i would like to get a set of our alloys. what were offset, wonder if i can get in uk. Did the original bmw centre caps fit and the tyre valve sensors.
