08-19-2019, 04:28 PM | #1 |
Rep 35
Bimmerworld m tech front lip
I ordered this part and it arrived with a tube of liquid with the hardware. What is this used for? Has anyone installed this lip before?
Thanks. |
08-20-2019, 10:55 PM | #5 |
Rep 35
installed. Fit was perfect and installation was easy.
11-04-2019, 11:46 PM | #7 |
Rep 35
11-10-2019, 04:40 PM | #9 |
Rep 35
I just lined up the lip on the bumper and unscrewed the hardware in the bumper where the holes lined up with the lip. Then I put the adhesive on and then put screws into every hole in the lip that I could
11-11-2019, 09:06 AM | #10 |
Rep 267
Gotcha. thanks. Got it installed this weekend. Didn't even need to lift the front end
02-15-2020, 02:31 PM | #11 |
Rep 230
Drives: 2018 240i
Nice
Looks nice I may have to get that for my m235i
Is it gloss or flat finish ? Are you still happy with it after some miles on it ? Where did you get it ? I am not familiar with sellers ? I am new to this BMW thing. Hap |
02-15-2020, 02:35 PM | #12 |
Rep 35
It is a matte finish. Still looks good after 5k miles. I got it from bimmerworld. It's the "m tech front lip" on multiple sites and is essentially a reproduction of the oem m performance front lip.
02-15-2020, 02:39 PM | #13 |
Rep 230
Drives: 2018 240i
Ok
Thanks Arc....it really does look nice on your car.
Since mine is in winter storage I am looking for things to do to it Thanks for quick response. Hap |
09-10-2020, 03:24 PM | #15 | |
Rep 75
Instagram: @ninthvision
https://www.instagram.com/ninthvision/ if you're local hit me up for pictures or video |
09-12-2020, 05:59 PM | #16 |
Rep 558
I've had my eye on this for a while, finally ordered it today. Looking forward to installing it.
Edit: I got an email advising the lead time for fulfilling the order is 30-60 days... :-(
09-27-2020, 12:44 PM | #17 |
Rep 558
Mine arrived today, faster than I thought it would. I'll probably install it next weekend.
For those that have already installed it, did you glue the 2 parts together before installing the lip assembly on the car? Or, did you just put them together with the attached double-stick tape and then screw it onto the car? Trying not to overthink this, but want it to be securely mounted and stable. Last thing I want is for it to come loose at highway speed... Arc1703 , sandrik93 , DJR1971 , thoughts? Thanks!
09-27-2020, 02:04 PM | #18 | |
Rep 35
PeterWT252.50 |
09-28-2020, 09:20 AM | #19 | |
Rep 267
PeterWT252.50 |
09-29-2020, 12:01 PM | #20 |
Rep 75
That smaller circled piece goes inside the larger lip piece correct? Or does it attach separately?
09-29-2020, 07:22 PM | #21 |
Rep 558
Yes, the smaller piece goes inside the larger piece. It only fits one way. I glued them together using the supplied glue and clamps because the attached tape didn't hold well. This should have come assembled from the factory. But, I guess for ~$300 less then the BMW part, they have to cut costs somewhere... some assembly required.
09-30-2020, 11:04 PM | #22 | |
Rep 75
