2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning Stage 2 91 Logs
      07-31-2023, 07:19 PM   #1
M8fam
M8fam's Avatar
Drives: 2021 M240ix
Stage 2 91 Logs
Hello All,
Please take a look at my BM3 Stage 2 91 logs and let me know your thoughts.
Right now I'm running non ethanol, pure 91 octane. The car runs noticeably better, but it appears I'm still getting timing corrections? New set of NGK spark plugs as well.
Should I try the ACN91 Map? I'm in Colorado btw.
https://www.bootmod3.net/log?id=64c8...90c638785e2d5c
      08-01-2023, 08:32 AM   #2
JMcLellan
JMcLellan's Avatar
Drives: 2024 M2
Originally Posted by M8fam View Post
Hello All,
Do you have access to higher octane gas, or ethanol? If it were me I would throw in a couple gallons of E to clean up the timing corrections. Throttle position and boost looks good throughout the pull.
2024 M2
2019 M240i- Sold
      08-01-2023, 09:28 AM   #3
M8fam
M8fam's Avatar
Drives: 2021 M240ix
91 octane is the highest in this region. I do have access to e85, but since switching to non ethanol.. the car just runs better. Iíll keep it in mind regarding adding more ethanol.
JMcLellan2021.00
      08-01-2023, 09:39 AM   #4
n55david
n55david's Avatar
Drives: 2017 m240i, 2015 X3 x35i
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
Hello All,
100% switch to the acn map. You're fuel is god awful.
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      08-01-2023, 10:48 AM   #5
M8fam
M8fam's Avatar
Drives: 2021 M240ix
Interesting. What is your opinion on mixing 91 with e85 vs 110 race gas. Will look into ACN91 as well.
      08-01-2023, 11:00 AM   #6
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
I would immediately switch or add octane tbh..
Adding e85 is fine, adding a gallon or two per tank will likely take care of the problem. 110 race gas is fine too if it's unleaded.
      08-04-2023, 08:04 AM   #7
M8fam
M8fam's Avatar
Drives: 2021 M240ix
I dropped to ACN91. What do you guys think?
https://bootmod3.net/log?id=64cc255ad10b43eaaf6feba6
      08-04-2023, 03:12 PM   #8
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
It's better but it's not right.. iats are a bit high too. Whats the temp there? What plugs?
Actually.. can you do start the log at just after 2000rpm and instead of letting off, can you let it shift to 4th gear and then let off after running through 4th?
      08-04-2023, 03:58 PM   #9
M8fam
M8fam's Avatar
Drives: 2021 M240ix
Temps around 85F, plugs are NGK 94201.
Anyone youíd recommend to fine tune the map? Donít need a full on custom tune
      08-04-2023, 07:28 PM   #10
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
Do the logs I asked for.. I need more info before I can suggest what you need to do
      08-05-2023, 03:33 PM   #11
M8fam
M8fam's Avatar
Drives: 2021 M240ix
Here is another log:
https://www.bootmod3.net/log?id=64ce...90c6ba464ab538
      08-05-2023, 05:10 PM   #12
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
Yeah, your fuel is just really bad. I'd add a gallon of e85.
      08-05-2023, 05:57 PM   #13
M8fam
M8fam's Avatar
Drives: 2021 M240ix
Thanks for reviewing. I have a tu hpfp. I might as well explore E30 or other maps if mixing ethanol is unavoidable.
n55david1295.50
      08-06-2023, 09:20 PM   #14
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
It wouldn't hurt but adding a little e85 won't require any difficulty or math lol
      08-09-2023, 02:47 PM   #15
JMcLellan
JMcLellan's Avatar
Drives: 2024 M2
You won't need to be on an E30, E40, etc map to allow for experimentation with ethanol. I use it when running my stage 2 93 octane or stage 2+ 93/95 octane maps. I put in 2 to 4 gallons of E when I fill up. Then every few fill ups I just use 93 octane. Then start over with E the next time. It's been working great for me.
2024 M2
2019 M240i- Sold
      08-09-2023, 06:56 PM   #16
M8fam
M8fam's Avatar
Drives: 2021 M240ix
Did another run today with 2gals of E85. Looking much better
https://www.bootmod3.net/log?id=64d4...90c62e93ab88f9
Search this Thread:
