2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning Update on B58 problems - finally resolved
      08-17-2022, 10:30 AM   #23
LuckyMike
Drives: M240, X3 M40i, 320ix, X5 35d
Kern, let me clarify, in my case the PCV valve did not fail. I was describing another common issue with allowing the car to idle for an extended period as an example. My issue was turbo failure with resulting engine failure (turbo shaft nut was found somewhere other than on the shaft and the turbo was destroyed). I am making an assumption that the root cause is related to idling the car for an extended period immediately prior; the correlation seems too likely to ignore.
Aleksander, the initial quote was for a replacement engine and turbo (brand new). My dealership has been excellent to work with and has reduced the quote significantly so this car that is in otherwise perfect condition can be repaired instead of scrapped.
      08-20-2022, 04:53 PM   #24
jzeiler4
jzeiler4's Avatar
Drives: 2021 M240i xDrive vert
Please define what "idling for an extended time" is? 10 minutes, 30 minutes, an hour?? In other words how long did you idle your engine before the turbo blew.
      08-22-2022, 11:13 AM   #25
kern417
Cheapskate
4445
Drives: 2018 440i |2016 340i | 2010 X5
that's just crazy.
not that PCV's failing from extended idling makes any more sense
but taking out the whole engine makes no sense to me. i would push the dealer to provide more specifics on how that actually happened and diagnose the root cause, although they probably won't.
Originally Posted by umizoomi View Post
As long as 3-pedals are an option, I will exercise my right to suffer the handicap and indignity of slower shifts and reaction times.
Youtube/Instagram/TikTok: @kern417
Search this Thread:
