09-27-2020, 08:44 PM | #1 |
Rep 1,289
can I stack my flash tune?
I recently got the dinan flash on my car and wondering if I could stack something like the JB+ on top of it to give me just a bit more power? if it's possible, what are the advantages/disadvantages of doing this?
09-29-2020, 07:16 PM | #2 | |
Rep 294
Drives: 2019 M240i Coupe RWD
JB+ on top of a ECU tune would be a horrible idea. JB+ was designed to work with the stock settings and the ECU tune was designed to push to what Dinan considered the safe tune with no need for any additional devices mucking with sensors. Probably still a bad idea, but you could possibly put a JB4 with a custom tune on top of the ECU tune, but why not just buy the appropriate ECU tune in the first place that gives you the control/performance you want? |
mblaucoupe135284.50 |
09-29-2020, 07:31 PM | #3 | ||
Rep 1,289
09-30-2020, 07:57 AM | #4 |
Rep 61
I actually tried this, testing a theory that I was maxing out my TMAP sensor during hot weather.
I put in a 3.5bar sensor instead of the 2.5bar one, and connected the JB+ on top of one of the first available stage 2 Flash tunes. (I've since wiped it back to stock and installed BM3 stage 1) I had (still have) a Wagnar 300CPI catted downpipe. I am pretty sure the engine did not know what the hell was going on. The torque on my test run was very noticeable. I was calculating torque and HP by logging GPS and OBD2 data - as a reference point, BM3 St1 I'm calculating at about 620nm/390HP. With the JB+ there was over 750nm and almost 430hp during that run iirc. I did not find clear enough roads to get any proper data, but the low down torque increase was actually pretty scary. Then the engine seemed to dial itself back to normal power levels after just one restart. There were fault codes all over the place due to the incorrect sensor type. I took the JB+ and sensor out pretty quickly, but it was an interesting test. Basically a bad idea, and pretty pointless unless you're after some specific data-point. I have not tried the sensor with Bootmod3's 3.5bar sensor setting yet. |
09-30-2020, 09:22 AM | #5 |
Rep 190,807
You can stack a piggyback with a flash tune. it's safe as long as you know how to datalog and make sure you are not adding too much boost.
I recommend the Jb4 instead of the JB+ as it lets you monitor boost and it has safety failsafes that will return the car to stock power if it's over boosting or running lean
09-30-2020, 06:49 PM | #6 | |
Rep 1,289
09-30-2020, 06:50 PM | #7 | |
Rep 1,289
09-30-2020, 10:13 PM | #8 | |||
Rep 336
10-01-2020, 07:12 PM | #9 | ||||
Rep 1,289
