11-06-2018, 08:37 PM | #2 |
Rep 91
I'm sure you could but if you are getting MB3 why would you want to stack up the JB+ on top ? A JB4 I could understand but the JB+ i'm not seeing a reason to keep it with BM3
'18 230i xDrive// Black Met // Coral Red // M-Sport // BM3 // BMS Intake // BMS OCC // Dinan Axleback // Daily Fun
JY01692.50 |
11-12-2018, 09:35 AM | #4 |
Rep 314
You could use the JB, but I wouldn't. The flash has already raised the boost, piggyback just trick your ecu to add more boost. No need for both. I just got the Stage 2 BM3 it's amazing.
Kiel McCaul
CapitaineBeaver22.50 |
11-12-2018, 09:42 AM | #5 |
Rep 91
Exactly, i've seen people stack tunes but the flash os the better option and will already alter engine parameter to raise boost and all. Your better off selling off the JB+ to recoup some of the cost of the BM3.
BostonM235xi130.00 |
11-15-2018, 12:29 AM | #6 |
Rep 190,805
Hi OP,
You can use the JB+ with BM3. Im assuming you want to use it because you want to add a bit more power to the OTS BM3 map
11-15-2018, 08:48 AM | #7 |
Rep 1,931
if your going to stack, make sure you log.
It will probably cause misfires because you don't have the fuel to support the extra boost. You can keep it in your glove box and put it on at the track, or if your going to pull a run, but I wouldn't leave it on full time on that engine. The jb+ is proven to add .02 seconds to a quarter mile time and good for 2-4 mph in the trap on the n55. It makes your car think its driving at high altitude, so will increase fuel/air = more hp safely.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic Last edited by bryan_G01; 11-15-2018 at 07:51 PM.. |
11-15-2018, 10:21 AM | #8 | |
Rep 823
11-15-2018, 11:24 AM | #9 | ||
Rep 91
