2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum Regional Forums USA - Northwest Palmer Motor Sport Experience
      07-13-2015, 11:21 PM   #1
BBMMWW333
Drives: C32 AMG, E63 AMG, M235i
I just got back from the track on Sunday and it was a big disappointment. My car was the slowest of them all. Even a stock Subaru WRX walk all over me.
The car is on A/S tires and it horrible with it! I wish I have gotten the RWD instead of the X Drive. This is great street car but not so much for the track. I will probably go again soon and get a set of new tires to see if this will make any differences. The A/S tires is garbage for the track.
      07-13-2015, 11:32 PM   #2
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
weird... not sure how a WRX could be faster....
so you think x-drive is the issue ?
      07-13-2015, 11:37 PM   #3
Transfer
Transfer's Avatar
5254
Drives: Bronco Wildtrak, Tesla MYP
Do you know how to drive? First time on track? Certainly the tires are a big issue but it's not a slow car.
      07-13-2015, 11:40 PM   #4
Transfer
Transfer's Avatar
5254
Wait. Why are you posting in PNW?
      07-13-2015, 11:40 PM   #5
BBMMWW333
The instructor and I think it's the stock A/S tires. but I'm sure it would be way better if this is a RWD M235i.
The track expensive changed my view on street cars vs track able cars. I went with a group of buddies and my car is supposed to be the best of them all. but it turns out very different on the track. I now understand the difference in the track vs the street.
These WRX and Sti are actually very fast on the track. I have the fastest straight line car compare to my friends WRX and STI. On the track is a complete different story. My instructor can't even keep up with a novice driver with my A/S tires, that how bad it was.
I think I will need to get better break pads and break fluid as well.
Note: The stock WRX is on A/S Continental ExtremeContact DWS tires.
      07-13-2015, 11:47 PM   #6
pikcachu
pikcachu's Avatar
1403
what where the other cars ?
and what kind of mods did they have...?
      07-13-2015, 11:53 PM   #7
BBMMWW333
Cars in our group:
Camaro ZL1 , STI , WRX, FRS and Modded EVO.
pretty much everything is stock on their car except exhaust mods.
      07-13-2015, 11:56 PM   #8
BBMMWW333
That's why I had my instructor test to drive the car. We know the tires is the main issue. but for him to have a hard time keeping up against a novice drive that is also on A/S tires in the WRX???? that's a big disappointment. Either the stock tires on my car is crap or the 4wheel drive system is not as good as the WRX.
      07-13-2015, 11:58 PM   #9
pikcachu
pikcachu's Avatar
1403
Cars in our group:
The ZL1 will kick any of those cars butt... it's a 600hp car
What tires do the subbies have ?
There is no way a stock FRS can be faster than the M235....
      07-14-2015, 12:02 AM   #10
pikcachu
pikcachu's Avatar
1403
I'm pretty sure the 4wd on the subarus are better.... they have 2 LSDs one in the front and one in the rear...
But usually 4wd it's not the best for the track anyway unless you are talking McLaren P1 4wd
      07-14-2015, 12:07 AM   #11
BBMMWW333
I'm not comparing to the other car. they all have PSS tires. so there's no way for my A/S to keep up. But the WRX is on A/S as well. that's the main disappointment.
The FRS is actually very good for that track. I am only able to use average of 40% -70% of the throttle based on the M Lap timer. The under steer is very bad with my setup. The tires screams on every turn at 40 - 50 mph.
I'm not saying this is a bad car but the tire needs to go for sure. The current setup is very a good as a street car but it turns out to be a big disappointment for the track. ( I'm not trying to start a flame war here)
      07-14-2015, 12:11 AM   #12
BBMMWW333
I would think that the BMW Xdrive can't be that bad compare to the subarus. but I was wrong...
      07-14-2015, 12:12 AM   #13
pikcachu
pikcachu's Avatar
1403
Maybe the LSDs of the subaru disimulate better the A/S....
Also seems to be a quite twisty track http://www.palmermotorsportspark.com...aps.aspx?Map=0 quite a few hairpins and slow corners where you can't use much horsepower...
Maybe an M235x with LSD would be a different story..
Was it dry ?
can you post your laptimer file ?
      07-14-2015, 12:23 AM   #14
BBMMWW333
Was it dry ?
PM'ed
      07-14-2015, 12:26 AM   #15
BBMMWW333
Was it dry ?
http://www.filedropper.com/20150712-...5194b2c8529ee6
      07-14-2015, 12:39 AM   #16
dharo1
dharo1's Avatar
Drives: Previous: F22 M235i ; F80 M3 ;
Or Porsche 918
Max speed 99mph? Really ?
      07-14-2015, 12:46 AM   #17
BBMMWW333
Originally Posted by dharo1 View Post
Or Porsche 918
A/S tires and stock break fluid, not trying to win any trophies there .
      07-14-2015, 01:07 AM   #18
pikcachu
pikcachu's Avatar
1403
Are you with DSC, DTC or DSC OFF ?
This looks weird
Like your throttle is cutting off
      07-14-2015, 01:39 AM   #19
dharo1
dharo1's Avatar
Or Porsche 918
True. Proper tires make a huge difference.
      07-14-2015, 09:27 AM   #20
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [7.68]
Remember guys, he is running on run flats. A very poor track tire.
But why is this posted in the NW section?
      07-14-2015, 10:05 AM   #21
BBMMWW333
This looks weird
I'm in sport+ with S mode.
      07-14-2015, 08:58 PM   #22
hoppy6698
hoppy6698's Avatar
Drives: M235i, Estoril Blue on Black
OP: As you mentioned, there are probably a few things you need to fix.
1) Post this thread in the track section for more track-oriented feedback.
2) Flush your brake lines and use ATE 200 brake fluid.
3) Run flats are horrid, hopefully you did a good job destroying them. You should be able to find PSS sets for sale on here as one option. Other track drivers have moved to square setups on 17 or 18s, and camber plates to extend tire life.
HPDEs are great events to learn more about your car and your own limits. Becoming a track rat requires forethought and planning - it can easily become an expensive hobby, albeit a fun one :P
Enjoy the track and drive - nothing wrong with the car, just some minor tweaks to see some real improvements!
