07-23-2014, 07:50 PM | #155 | |
Rep 5,262
Number flashing when unlocking FEM_BODY 3060 QUITTBLK_ENTSCHAERFEN_ANZAHL werte=02 Werte=X-1 Number flashing when locking FEM_BODY 3060 QUITTBLK_SICHERN_ANZAHL werte=01 Werte=X-1 So 1 flash when unlocking 0 flash when locking |
07-23-2014, 10:52 PM | #156 | |
Rep 333
07-24-2014, 11:00 AM | #157 |
Rep 449
Anyone know if we have this on our F22's. Found it on the F30 coding forum.
Temp Gauge on instrument cluster (although no reading is given - just a cold/hot slide bar) KOMBI ECU, 3000 Module, BC_MOTORTEMP_ENABLE changed from Nicht Aktiv to Aktiv.
'17 F80 (RET)
'14 F22 M235i (RET) '11 E90 335i (RET) '07 E92 335i (RET) '89 E30 M3 (RET) Last edited by jrstech; 07-24-2014 at 11:05 AM.. |
07-24-2014, 11:07 AM | #159 |
Rep 449
Just updated the code in my OP
'17 F80 (RET)
'14 F22 M235i (RET) '11 E90 335i (RET) '07 E92 335i (RET) '89 E30 M3 (RET) |
07-24-2014, 11:39 AM | #161 |
Rep 449
Here's what it looks like in n M135
'17 F80 (RET)
07-24-2014, 11:41 AM | #163 |
Rep 449
Crossing my fingers! Let us know.
'17 F80 (RET)
07-24-2014, 12:15 PM | #164 |
Rep 449
F30 OP claims it only displays the graphic, no reading just the hot/cold slide bar.
'17 F80 (RET)
07-24-2014, 05:19 PM | #167 | |
Rep 449
http://f30.bimmerpost.com/forums/sho...96777&page=317
'17 F80 (RET)
07-24-2014, 09:24 PM | #169 |
Rep 449
Totally sucks, I hope someone can figure it out.
'17 F80 (RET)
07-24-2014, 11:15 PM | #170 |
Rep 21
Anyone know why my Engine light turned on when I only did some simple coding from the cheat sheet???
EDIT: Now I fixed the engine light using tool32 but now it seems like the steering wheel became stiff and ill need to step harder to accelerate. Anyone know why that happened? Last edited by Xmas; 07-25-2014 at 03:47 AM.. |
07-25-2014, 04:04 PM | #172 |
Rep 21
07-25-2014, 06:35 PM | #173 |
Rep 5,262
Is it still on after cycling the ignition a few times?
were you coding with the car turned off? Is usually better to run the car or connect it to a trickle charger when you are coding so that the battery voltage stays stable else you might get errors if voltage drops below 13v you can clear any codes with e-sys and see if it comes back or not E-SYS can remove the fault code. Click "External Applications" in the left menu. Click "External Application" Double-click "Transmitter" Scroll to the bottom and double-click "... Clear all DTCs ..." |
07-26-2014, 03:05 PM | #175 |
Rep 449
The OP claims on his F21 that the slider just stays in the middle regardless of engine temp. I guess it's safe to ditch the idea of coding temp gauge on our f22's.
'17 F80 (RET)
