04-26-2022, 03:50 PM | #1 |
Rep 6
Help with swaying
Hi guys, I was driving in Miami and I caught a flat in my Hancook v12s, they weren't run flats so I was just driving on the rubber pretty much, car was bumpy but I was driving really slow like 10mph for about 10-20 miles until I reached the tire store. I put on some petlas velox sports 255/35/19s and got an alignment, after getting alignment I realized the car wasn't driving straight, whenever I floored the gas pedal the car would start to sway at top speed as if it's on a drag pack or something, whenever I went over a lane line the car would sway aswell. I'm wondering if anyone has any insight?
Ps: when I got the alignment, with my luck, I got a drivetrain malfunction for a hpfp related issue, keep in mind I'm 300 miles away from home so after I got the malfunction I just thought maybe that shop just didn't know what they were doing and fix it after I fix hpfp, fast forward I'm ready to fix it, just don't know where to start, bmw advisor at dealership said my tires are too cheap lol, I hope thats it but another alignment shop told me I needed an "roadside alignment" or some bs |
04-26-2022, 03:56 PM | #2 | |
Rep 547
For me, the swaying start getting noticeably better at around 2000 miles mark on the tire. |
04-26-2022, 04:00 PM | #3 | ||
Rep 6
Thank you for the input, what tires are you running if you don't mind asking? And do you think upgrading to a high quality brand would eliminate it? |
04-26-2022, 04:27 PM | #4 |
Rep 5,582
" shop told me I needed an "roadside alignment" or some bs "
did they say ' roadforce balance ' ? Did you get 4 new tires ? Everything Ajowhan said, your part about driving over painted road and feeling slipping sure does allude to tire contact as the cause. a few hundred miles of driving should wear off mold release chemicals and add some scruff for better feel. Really good proper speed rated tires are the best performance upgrade you can make. |
04-26-2022, 04:32 PM | #5 | |
Rep 6
04-26-2022, 04:40 PM | #6 | |
Rep 547
The cheapest tire I have ever run was a Lexani (Goes for a lil less than $100 a piece) on a lexus is 250 and back then I dont have any problem running 110-120mph. Yup, I have also never experienced that much sway from just tires. I was very surprised myself since this is not the first time I have fresh tires. The other things to be taken into consideration is that, some facebook group have mentioned that they run into similar issue when replacing only 2 out of 4 tires, others mentioned this is not the case for them. Mine is a lil unique because, when I replaced only 2 of mine. My car traction/stability control was actually lighting up in corner and my ABS was working extra hard even on light corner. I then found a small bubble on my front left tire. I end up replacing my front 2 about 1-2 weeks after the rear 2, so now I have all 4 sides new tire. With that said, I was still experiencing swaying with all 4 new tires till roughly about 2000 miles on my rear and 1500 on my front ish. I have never heard of subframe damaged while doing alignment so I can't comment much. But if your swaying is anything like mine, Im hoping it get better for you as you break the tire in. Once again, Im just as bewildered as you even now how much change can a car feels just by going to a new tire. |
04-26-2022, 04:43 PM | #7 | ||
Rep 6
04-26-2022, 05:44 PM | #8 | ||
Rep 3,611
Although I don't think it was relevant to my situation, the balancing was done on a Hunter Road ForceŽ Elite Wheel Balancer at the go-to shop in my region. Quote:
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9˝ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; Full PPF |
04-27-2022, 11:17 AM | #9 | |||
Rep 6
overcoil3104.50 |
05-03-2022, 06:22 PM | #10 | |
Rep 547
Mine is -0.8 camber -1.1 6.8 caster 6.8 0.03 toe 0.02 rear -1.6 camber -1.5 0.12 toe 0.13 |
