11-04-2018, 10:14 PM | #1 |
Rep 564
Will 265's fit with Dinan springs?
Looking at a 19X9.5 ET44 wheel. Will a 265/30 MP4S tire fit and not rub?
2019 M2 Comp, MT, BSM
2015 X5 Msport, CB (Hers) 2014 M235i MT, BSM, MPE, Dinan Springs (Sold) |
11-05-2018, 11:07 AM | #2 |
Rep 115
Look at the Dinan Site, they have their Stage 3 M235i wheel/tire specs on the site. I think they fit a 265 out back.
2014 M235i
11-05-2018, 11:40 AM | #3 |
Rep 1,183
- HRE FF15 Wheels 18x8.5ET40 & 18x9ET44 in Tarmac Black
- MPSS 235/40/18 and 265/35/18 This is my setup and it fits no problem. I think the 9.5 wouldn't be all issue either. There are a few 265 threads out there too that may specifically cover the 9.5 setup |
jmkr29.50 |
11-05-2018, 12:09 PM | #4 |
Rep 564
Most of the 265 info out there is on stock suspension.
11-28-2018, 08:59 PM | #5 |
Rep 97
I am actually looking to get the HRE FF15 wheels in the same dimensions with dinan springs. I was wondering what sizes would be ok for my xDrive M235i.
12-01-2018, 10:33 AM | #6 |
DisplacementReplacement
621
Rep 1,299
Any pic's of 235 front and 265 rears lowered or other?
2020 X3M /// MHD Tune
2017 240XI Hybrid Turbo / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 2007 328XI Stock |
12-02-2018, 10:38 AM | #7 |
Rep 201
Here was my setup on my last car: Dinan springs with BBS CI-Rs wrapped with 235 up front & 265 in the rear. Had this setup for close to 3 years and had zero rubbing, even when on the track.
12-02-2018, 10:42 AM | #8 |
Rep 1,304
Drives: 2021 C8 Corvette 1LT
19x9.5et44 with 265/35. I have about 5mm of poke and stock suspension. Looks to me that I would rub if I lowered. But who knows, maybe the slight camber when lowered would allow for a narrow miss
12-02-2018, 10:45 AM | #9 |
Rep 1,304
Also, Dinan fit 265 in the rear using the BBS 19x9et45 (or 47? IDR exact). That’s why they were able to fit the 265 in the rear. That slight inward movement of the wheel clears the fenders
12-02-2018, 10:47 AM | #10 |
Rep 1,930
could do with apex fitments... i could easily get a 265 out back, on 255 now.
tire manufacture will be the hurdle.
www.nybmwcca.org
12-02-2018, 01:05 PM | #11 |
Rep 213
Drives: 2024 BMW M4 Competition XDrive
I have the same setup as on the dinan website. Haven't had rubbing yet.
12-02-2018, 03:34 PM | #12 | |
621
Rep 1,299
18 or 19's ???
12-02-2018, 03:58 PM | #13 | |
Rep 643
M235i rwd 6mt
12-02-2018, 04:20 PM | #14 | ||
Rep 201
Dinan springs with alignment as close to stock as possible This setup is perfectly flush front and rear |
designatedposter177.50 bhbnuckle0.00 |
12-03-2018, 11:51 AM | #15 | |||
Rep 213
12-24-2018, 11:48 AM | #16 |
Rep 1,365
I'm going to make the leap from 255 Pilot SS to 265 P4S next spring. I'm running Apex EC-7 18x9.5 et58 with a 5mm spacer, so effectively an et53 offset. If a 9" et48 works, I'll be 1.35mm further out. Should be fine on the outside, but possibly some slight rub on the strut cover? I'm on Dinan springs too.
12-24-2018, 06:43 PM | #17 |
Rep 1,304
I’d measure everything as your car sits right now with spacing to the fender and strut, and then take those measurements and tire sizes over to https://www.wheel-size.com/calc/ and I put all of that information. It will let you see how the new tire size will fit in comparison to your new setup.
01-18-2019, 11:46 PM | #18 |
Rep 169
Found this thread. Good info
I'm running 19x8.5 235/30/19 ET35, 19x9.5 265/35/19 ET45. It seems like they should just fit with Dinan springs based on what's been posted here already. I'm going to measure and use the Wheel Size website posted though. Anyone have reason to think my fitment would not fit?
Current: 2019 M2 Comp, Coilovers, Camber Plates, Rogue SSK, AA Single MP, BM3 Stg 1
Sold: 2015 M235i RWD, MHD Stage 2, FBO, MPE, XHP, HPD5Evo | IG @sea_m235i |
MyMiniM333.00 |
01-20-2019, 10:45 PM | #19 | |
Rep 174
02-03-2019, 07:37 PM | #20 | |
Rep 1,365
02-03-2019, 08:47 PM | #21 |
Rep 1,304
This is my vmr v801 with 265/35/18 PS4S. I don't think Dinan springs alone will camber the back enough to clear the quarter panel.
Project Car: DF Goblin
-Built LSJ-T 2021 C8 Corvette 1LT 2021 Model Y Performance |
02-03-2019, 08:49 PM | #22 |
Rep 564
What offset?
