08-27-2020, 12:37 PM | #1 |
Rep 1,450
Wheel questions for M240i owners
Wheel question for M240i owners (RWD only)
As I have now given up trying to get a good Offset for a staggered set up. I have come to the conclusion I will need to get a square set up and run different size tyres front and rear. Has anyone got 18" ET40 8.5j square set up, on oem suspension, without any camber adjustments or spacers, running 235 up front and 255 rears? Without any rubbing issues. I am concerned on the front wheels more due to the wheel being closer to the strut by 7.7mm over oem wheel size
M240i LCI (Mineral Grey):- M2 Door Mirrors, M2 Black Kidney Grills, Lower grille inserts, MP Exhaust, Dinan Carbon Fibre CAI, hot climate intake elbow
08-27-2020, 01:09 PM | #3 |
Rep 1,450
Cheers that's good to know. Are you on oem suspension too? What are you running on the rear?
08-27-2020, 06:12 PM | #4 |
Rep 674
08-28-2020, 03:23 PM | #5 |
Rep 292
Alutec Drive 18x8 et43 black and silver with original mpss tyres. My M240i is Glacier Silver and in my opinion they look great. Once the fronts need to be replaced I am going with a square setup 245/35/18. No rubbing.
08-28-2020, 05:01 PM | #6 |
Rep 503
BEYERN RITZ Gloss Gunmetal with Brushed Face (18" x 8.5", +35 Offset, 5x120.65 Bolt Pattern, 72.6mm Hub)
PILOT SPORT 4S Tires by Michelin®. 225/40ZR18 BEYERN RITZ Gloss Gunmetal with Brushed Face (18" x 9.5", +45 Offset, 5x120.65 Bolt Pattern, 72.6mm Hub) PILOT SPORT 4S Tires by Michelin®. 255/35ZR18 |
Si-M240i142.50 |
08-30-2020, 08:34 AM | #7 | |
Rep 1,450
08-31-2020, 09:36 PM | #8 | ||
Rep 503
https://fitment.beyernwheels.com/all...38;model=M240i https://www.beyernwheels.com/bmw-whe...lue%20Metallic I don't see weights listed. |
Si-M240i142.50 |
09-01-2020, 12:17 PM | #9 | |
Rep 3,611
Si-M240i142.50 |
09-01-2020, 10:55 PM | #10 |
Too many cars, not enough time
44
Rep 73
I have 18x8.5 +45 square, 5mm spacer in front, 245/35 tires all around. Works fine.
Alignment is -2F/-1R for camber.
FOR SALE: 2017 ///M240i, 6 speed, slick top, Estoril Blue. https://www.2addicts.com/forums/show....php?t=1865469
09-02-2020, 12:52 AM | #11 | |
Rep 529
225 is a little narrow for the 8.5 in front. looks a little stretched, so I would go for 235 as you planned.
E46 -> E90 -> F30 -> F23
09-02-2020, 01:09 AM | #12 | ||
Rep 1,450
