2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Dr. Strangelove, or How I Learned to Stop Worrying & Live w the Harmon Kardon System
      05-08-2020, 06:51 AM   #837
selmeralto
selmeralto's Avatar
227
Drives: 2021 M2 Competition
Originally Posted by Getzinem View Post
Thanks so much for making this. I am in the process of making a video series on this. Would you mind if I gave you and this thread a shoutout?
Hi Getzinem,
A video is a great idea and I'm sure lots of people would appreciate it. Sure, feel free to mention the thread. No need to mention me personally, especially since there were so many people who have also contributed to the thread. I look forward to seeing the video. Thanks.
      05-08-2020, 11:40 AM   #838
Getzinem
Drives: BMW m235i
Originally Posted by selmeralto View Post
Hi Getzinem,
Thanks. That's very kind and humble of you. You're a good person. I'll have it out soon. Thanks again!
      05-10-2020, 01:46 PM   #839
Getzinem
Drives: BMW m235i
Hi Getzinem,
State 1 is all done. Thanks again
Stage 2: ASD Delete
      05-14-2020, 08:35 AM   #840
BrettKA7
Drives: F22 M240i
I was unimpressed with Harmon Kardon with all the settings neutral within the sliders.
However, moving the slider to the rear a bit helped improve the sound significantly! I have plans to disable the center speaker eventually but for now, moving the slider to the rear a bit turned the HK system from tinny and awful to perfectly livable.
M240i | Mineral White | Coral Red
      05-14-2020, 07:43 PM   #841
H2O_Doc
H2O_Doc's Avatar
Drives: BMW M2C, GLB-250, C7 Z51
I added the JL speakers to the back and faded the single back to those speakers and it's certainly better than stock.
      05-15-2020, 06:48 PM   #842
Murf
Drives: 2021 G80 M3C - Dravit Grey
Can anyone here help me - would like to try something a bit higher sensitivity than the JLs... Will these fit the deck on a coupe? JBL GTO-429
https://www.amazon.com/JBL-GTO429-Pr...otNum=2&sr=1-2
      05-17-2020, 05:46 PM   #843
MarcoZandrini
Drives: 2018 M240i
Hmmm, my sound stage is a little to far back for me.
      05-29-2020, 10:11 AM   #844
BEM-S4
BEM-S4's Avatar
FINALLY got lossless music out of my iPhone, through a standalone DAC, and into the car while still charging my phone. Big thanks to MarcoZandrini for the help on this!
This only works for cars with Aux-In armrest input, but you need:
Apple Lightning to USB 3 Camera Adapter
Audioquest Dragonfly (I used Red)
Short audio cable (I used one from FiiO)
From there install is very self explanatory, you plug your phone into the Camera Adapter, then hook up the Dragonfly to the USB and attach to Aux In. You then use a lightning cable to plug into USB for power. Proclip users, you need to replace your standard lightning to USB cable that came with your dock with this one on Amazon:
EMATETEK Extender Cable Connector Pass Audio Video Music Photo Data and Power Charge. 1PCS Male to Female Extension Cord Made of All Black PVC &Aluminum. (6.6 Feet / 2M)
You will need to file the hole in your dock a tiny bit, 30 seconds of work.
The photo below if from my wagon, I did both cars. The only difference in this case is that I had the OEM phone cradle, which I removed and added an additional USB outlet down inside the armrest. I plugged into that instead, but it works the same way.
      05-29-2020, 12:41 PM   #845
MarcoZandrini
Drives: 2018 M240i
Glad to help and inspire.
      05-29-2020, 04:23 PM   #846
Encanto
Encanto's Avatar
Drives: 2021 X3 M40i
I may be missing the whole story of this, but NBT units can play lossless files via USB. Why all the adapters to play lossless via AUX when AUX has the poorest audio quality of all sources?
      05-29-2020, 05:16 PM   #847
BEM-S4
BEM-S4's Avatar
The DAC in the head unit is crap - the only option is to feed the highest quality analog signal possible into Aux-In. Using USB in means the car is converting to analog.
The other choice would be to go direct into aftermarket amp via USB but again that will not charge your phone so you still need an adapter. You don't want the car or your phone handling the digital to analog conversion neither has a quality processor.
      05-29-2020, 07:16 PM   #848
Encanto
Encanto's Avatar
AUX In is the worse source in audio quality in the NBT - it does two conversions: AD and then DA. USB does one conversion: DA. And can play lossless direct. And charge your phone.
But if you are happy then that is what matters - to you. For everybody else, just use lossless with the USB already there.
      06-27-2020, 11:52 AM   #849
selmeralto
selmeralto's Avatar
227
Apparently, there's a component (the CAN BUS) in the factory amp that's needed to upgrade your car's software. The component isn't available on the Bavsound amp so if you've installed a Bavsound the dealer won't see the CAN BUS and the car won't update. If you want the update you have to disconnect the Bavsound amp and reconnect the factory amp.
The discussion is here:
https://www.2addicts.com/forums/show....php?t=1729449.
Forewarned.
      08-02-2020, 07:54 AM   #850
Jmon34
Drives: 2024 M2
I recently got a 2020 M240i with an HK system and like many others I'm ready to do something to fix the OEM sound. This thread has been an amazing source of information, I just finished reading through the entire thing.
I'm going to start with the center speaker disconnect and code off the ASD as soon as I post this.
I plan on going with the Etons B100W's in the front and either the B100N's or B100XN's in back.
Things I could use some advice on:
1. Is it worth an extra ~$100 for the N vs XN in the rear?
2. I've seen lots of conflicting information about the B100XHP crossovers/filters in the thread. Are they needed if I'm planning on keeping the OEM amp?
Originally Posted by Viffermike View Post
I would use them if you don't use a crossover anywhere else -- say, within an aftermarket amp, DSP unit, etc. They are basically the same thing as the physical crossover units supplied with most other component speaker sets -- which are also optional if you're using crossovers anywhere else.
Just to be safe, I would install the Eton filters if you're installing only the Etons (i.e., running off the OEM amp).
Be mindful, however, that if you upgrade the amp, add a DSP, etc. after that, you should not use any similar function on it. It's generally not a good idea sonically to 'double up' frequency filtering, especially when it's likely two types of it: electrical (the Eton part) and electronic (the amp/DSP).
Hope this helps!
Nick,
Tried to PM you, but your box is full ...
Sorry for the tardy reply; been busy the past week with work and a few forums.
Question: Do you run an aftermarket amplifier? If you do and it has adjustable high-pass filtering and/or crossovers, you don't need to install the Eton units. As I explained in another post (IIRC) in the Strangelove thread, one should almost never use two sets of crossovers with a speaker array. The crossovers in the amp will almost certainly be better than the Eton ones.
Now: The B100 XHPs are high-pass filters; they are NOT crossovers. All they do is prevent bass frequencies (150Hz and below) from reaching the woofer and tweeter. The OEM amp is already doing this. So, IMHO, there is no need to install them in any situation except if you're running an aftermarket amp without internal high-pass filtering.
Hope this helps ...
... Oh, as for Dynamat: It can only help if installed reasonably well. If you do it, cover the speaker openings and the flat area around those (several inches' worth). But since you've already got the speakers in, I wouldn't go back in to do it unless you have to for another reason.
- Mike
3. Is there any unobtrusive way of getting quality or lossless audio without an AUX port? My preferred music source is Tidal HiFi. I'm running an Android phone with a built in HiFi DAC on the headphone jack and Bluetooth codecs: SBC, AAC, aptX, aptX HD, and LDAC. So far the only way I've been able to get music from my phone to the car is Bluetooth connecting on AAC.
Thanks for all the info and any help!
Edit: people might be interested in this too. Built in eq settings in bimmercode that perform much better. I'm going to give it a try later.
https://www.2addicts.com/forums/show....php?t=1723637
      08-02-2020, 02:09 PM   #851
nikijack
Drives: 2016 M235i, Grey, manual
Technic PnP
Hi: Does anyone know of an alternate harness to the TechnicPnP, please?
Jack
      08-08-2020, 03:20 PM   #852
jv92red
Drives: F22 M240i (SOLD) E92M3 (SOLD)
Yes: Check out ebay seller 73mustangconv
https://www.ebay.com/itm/BMW-E90-F10...V4UKR&LH_All=1
His harness has higher quality RCA connectors compared to the Technic harness. The harness doesn't come standard with a relay, that is $10 extra per the description in the ad but there is no need for a relay even if your connecting 2 or 3 external amps. The coil on some relays will pull upwards of 200ma from the remote out which may be more than the total remote amperage draw from several amps combined. Just pigtail off the remote wire as needed for amps, DSP, Etc. For those insisting on using a relay make sure you have a flyback suppression diode wired for your relay.
He sells a basic version for people who want to run their own speakers wires from their own amps.:
https://www.ebay.com/itm/BMW-E90-F10...V4UML&LH_All=1
      10-16-2020, 08:19 PM   #853
TropikThunder
Drives: current: 330i next: x3 M40i
Old thread I know, but I'm going through the same research process for how to upgrade the sound in an M240i.
Generally, no, separates in the back seat aren't worth the additional cost. Tweeters work best at ear level, so one main advantage of the separates is better positioning in the sail using separates vs in the door panel using the coax. In the back package tray, the entire speaker is closer to ear level to start with so it's a moot point.
The other main advantage of the separates is a better crossover (or in Eton's case just a high-pass filter). Some coax manufacturers include a crossover/high-pass filter within the housing but many don't, and I can't tell if Eton does or not. But their separates clearly have a high-pass filter. The result is limiting the frequencies that reach the tweeter (>6k I believe) so it's not being asked to reproduce a frequency that it's not capable of (aor at a minimum not very good at.
I honestly believe the Eton manual is wrong on this, maybe it's a translation error? The factory HiFi amp has a Digital Signal Processor (DSP), so the two sub channels get 150Hz and below, while the Midrange/Tweeters get >150Hz. If you switch to an after-market AMP that doesn't have crossovers or a DSP, and it's sending full-range to the speakers, then you want the B100XHP high-pass filters to do what the OEM Amp was doing: block 150Hz and below from reaching the Midrange/Tweeters. If you stick with the OEM Amp, it should already be restricting the frequencies that reach the Midrange/Tweeters so the B100XHP would be redundant. I haven't been able to confirm this yet, maybe I'll email Eton.
Another source of confusion on the crossovers is that the Eton Installation manual refers to installing crossovers when using the separates. In this case, the crossover (again it's actually actually a high-pass filter) is the one that is daisy-chained between the Mid and the Tweeter and is shown in the picture in post #804. So there are two crossovers being mentioned: the one that comes with the B100 W separates and the B100XHP accessory.
      10-21-2020, 06:59 PM   #854
Jmon34
Drives: 2024 M2
@TropikThunder
Thanks for the insight and clarification!
      10-25-2020, 12:23 PM   #855
RitaClark
RitaClark's Avatar
Drives: BMW 7S RED
Originally Posted by nastypoker View Post
Yeah it's just a shame because using my phone on bluetooth is so convenient. If it wasn't for the crackles, I would be happy with bluetooth audio quality on these new echo dot speakers I have now.
So I want to be able to answer calls using the car system, have no crackles from bluetooth audio when listening to music and use the steering wheel controls. It seems my only option is to have music on a USB stick or pre-load onto the cars HD and then have my phone on bluetooth just for calls.
Bit annoying as I update my music library on my phone regularly so I need to do that with the USB stick as well now.
How do you do this? Easy, you need a long-range Bluetooth transmitter/receiver, such as the 1Mii B03. This allows you to stream audio from pretty much any device – cellphone, tablet, laptop, or desktop – to your sound system or speakers.
      02-20-2021, 01:42 PM   #856
premi23
Drives: bmw m240i
Speaker Connector Harness question
I want to purchase the harness from ebay seller: 73mustangconv
But I am confused as to whether I have to order 1 or 2.
His post says "ONE PAIR" does he mean a single pair of wires turned into a harness, or a pair of harnesses for both driver and passenger sides?
So in short, do I order 1 or 2?
edit: it was for both the driver and passenger side.
      03-27-2021, 06:48 PM   #857
premi23
Drives: bmw m240i
Viffermike
selmeralto
What's a good alternative to the Eton B100W if I already installed the JL's for the rear?
I want the Etons but I'm not sure where a safe place to order from is..
      03-27-2021, 06:57 PM   #858
selmeralto
selmeralto's Avatar
227
Originally Posted by premi23 View Post
Viffermike
selmeralto
Have you tried writing to Madisound?
