06-03-2023, 11:01 PM | #1 |
Rep 121
Removing adhesive from spoiler on matte paint
Anyone know if wd40 or 3m general adhesive auto remover is better for getting the adhesive off from the oem spoiler? Or any other suggestions welcomed
06-03-2023, 11:32 PM | #3 | |
Rep 1,682
Wonder Wheel 4" Decal Remover Eraser Wheel Toolkit, Remove Car Decals, Vinyl & Stickers in Minutes, Adhesive Remover Rubber Wheel, Emblem Removal Tool, Adhesive Eraser, Drill Adapter Supplied https://a.co/d/cSkozOU |
06-04-2023, 11:40 AM | #5 |
(formerly exe36M3)
47
Rep 61
1. Rub what you can off with your fingers.
2. Follow-up with WD-40 and a paper towel. Make sure the towel is fairly "wet" with WD-40. The towel is "aggressive" enough to pick-up the adhesive, the WD-40 breaks down the adhesive and keeps it from resticking. 3. Use a degreaser like Simple Green or quick detailer with a microfiber to get the WD-40 off the body. 4. Give the area a small patch of wax to protect the paint. WD-40 is amazing for getting decal residue off paint.
BMW CCA Member | 2015 BMW 435i RWD, Stage 1 Bootmod3
06-04-2023, 11:44 AM | #6 | |
2434
Rep 11,668
Don't need chemical solvents, just use and eraser wheel. goto 6:30 for eraser wheel.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
adam12hicks250.50 |
06-04-2023, 01:23 PM | #7 |
Rep 1,254
Wax, eraser wheel, buffing?
I'm guessing many here are not familiar with frozen/matte paint as you CANNOT rub the paint! I don't know what kind of adhesive is left, but if you can just slowly pick at it without rubbing the paint, that's your best bet. Other than that, maybe take it to a shop that has experience with frozen paint and see what chemicals they recommend. |
06-04-2023, 01:32 PM | #8 |
Rep 328
The all natural solution. Works great....https://googone.com/goo-adhesive-remover-spray-gel
2023 M4 Comp
Dravit Grey Metallic |
