06-03-2023, 09:18 PM | #1 |
Rep 2,015
So I finally was able to get my first car wash done and gotto say I was very nervous but turned out great. It also was very therapeutic and kinda gives u some time to just relax and do your own thing. The 827M wheels were a pain to clean but this is what I did
1. Wet wheels with hose, Used P&S Brake buster. Then let is sit for few min and used a hand microfiber mitt and woolywormitt brush to clean them. Rinsed with hose 2. Wet the whole car with garden hose and then used MJJC foam cannon with Adams Mega Foam. It turned out great !!! Let it sit for 5-6 min and Used a hand Mitt and gently wiped the foam being careful not to press too hard. Used 2 buckets of water to rinse the mitt in between to make sure no dirt is stuck on the mitt. Used 40 deg nozzle on my Greenworks pressure washer and rinsed the whole car thoroughly. 3. Used the Rag Company Liquid8 drying towel and I was amazed how much it sucked the water off. I gently laid it on the panel and just dragged it without putting any pressure and it wiped it clean without any streaks. I was able to wipe the whole car with just one towel. I used a separate drying towel to wipe the side skirts as it was too low to the ground and didn’t want my large towel to pick up any dirt on the ground. 4. Used Griots Speed shine and used rag company clean microfiber towels to apply them. They turned out great and the shine was amazing and just like when I first got the car. I’ve been lazy in the past about washing car and just used the laser washes but I couldn’t believe the difference between the two. There were zero water spots or run offs. If time permits I hope to hand wash my car Atleast once or twice a month and use the touchless as little as possible. Anyone is on the fence about washing their car, just do it. It looks daunting but once u get the steps right, it’s very simple. Just need the right tools and give urself enough time. Cheers |
14
grannyknot950.50 DanG10641.50 MaC-N54-E82438.50 OtoPA380.50 snareman9050.50 fraschusa191.00 icj_45e108.00 1209582790.50 (K)1270.50 Gladius Nova77.50 T0RM3NT3624.00 CT335xi684.00 ///MPhatic13855.50 james1138122.50 |
06-04-2023, 11:46 AM | #2 |
Rep 869
I never thought I'd see wheels as diabolical to clean as the 666m lol.
2018 F80 M3. YMB/BLK. ZCP. Three Pedals.
"Education will never be as expensive as ignorance." |
06-04-2023, 12:12 PM | #3 |
Rep 6,930
Drives: 2018 M2 AW DCT
Love the color of your M3.
I haven’t seen the need for a pressure washer so I just use a Groit’s foam sprayer that attaches to a regular garden hose.
BMWCCA member Puget Sound Chapter
Aalfred2605.50 RaisinCain2731.50 |
06-05-2023, 03:14 PM | #8 | |
Rep 230
The bolded part was the only thing I was wondering about what other folks think... When doing the snow foam, should you wipe that by hand at all, or just rinse it off? I thought you just rinse it because in theory it'll have suspended dirt in it. I always just rinse it, then move on to what you did next with buckets. Cheers! |
Aalfred2605.50 |
06-05-2023, 04:18 PM | #9 | |
Rep 56
I take care of the tires and wheels before/during the initial foam and rinse cycle especially since some tire and wheel products now require application to dry tires and wheels. In those cases, I do the tires and wheels first and rinse and then let them be part of the foaming and rinses later on. |
Aalfred2605.50 |
06-05-2023, 05:30 PM | #10 | |
Rep 509
My method is this... Spray my lower panels with a citrus pre-wash at a 20:1 ratio or ONR at a 256:1 ratio and let it dwell for a few minutes. I then snow foam over the top of the citrus or ONR to extend the dwell time, after around 5 minutes I rinse the car off. I then do the contact wash using the 2 bucket method and whatever shampoo I decide to use, it's usually Gyeon. |
RaisinCain2731.50 |
06-05-2023, 10:19 PM | #11 | |
Rep 2,015
https://youtu.be/xJO0u-Sy-mI |
06-05-2023, 11:20 PM | #12 |
Rep 234
Looks good my friend.. I was using a cannon hooked up to a water hose. Then a friend got me a basic electric pressure washer last week. Night and day difference.
For drying.. Lose the towels. Get yourself an ego 765 from lowes. You wont regret it. |
06-06-2023, 05:51 AM | #13 | |
Rep 230
Aalfred2605.50 |
06-06-2023, 08:08 AM | #14 |
Rep 56
Absolutely agree! The biggest benefit, by far, comes from opting to hand wash your car at all and taking care to do that "right" rather than taking your car to an automated car wash. Everything beyond that is fine tuning of your methods, finding products you like, etc.
Aalfred2605.50 |
06-06-2023, 12:38 PM | #15 |
Rep 2,015
Thanks. Yeah, the more I looked into pressures washers, I was going down the rabbit hole with cost. Just got a basic greenworks 2.3 gpm and 1200 PSI and it did the job well. So glad I was able to find an OK one. I tried my Dewalt leaf blower and it still left water spots. So switched to the towels. Really cut back a lot on the drying time. I do have a backpack Husquvarna leaf blower. Maybe will try it next time to see if it dries faster lol
06-06-2023, 01:18 PM | #16 | |
Rep 230
RaisinCain2731.50 Aalfred2605.50 |
06-06-2023, 08:22 PM | #17 |
Rep 234
06-07-2023, 07:16 AM | #18 |
Rep 230
06-07-2023, 07:42 AM | #19 |
Rep 148
This may be true for some products that are only designed to be used as a snow foam, but many car "shampoos" (Carpro Reset, Koch-Chemie Gsf and many others) are equally usable to foam the car with a gun and to contact wash with a mitt or pad.
Aalfred2605.50 |
06-07-2023, 01:20 PM | #20 | |
Rep 2,015
https://www.amazon.com/Rag-Company-A...23768293&psc=1 |
rmedina114.00 |
06-07-2023, 05:03 PM | #21 |
Rep 509
That may be so but I'd never ever use a snow foam for a contact wash, but it's up to the individual how they wash their car.
06-08-2023, 08:28 AM | #22 | |
Rep 6,912
First you sheet the water with a hose with no nozzle, then the leaf blower, THEN a good quality MF drying towel. Minimal contact w towel will keep your car swirl free.
2022 Dravit/Fiona M3cx - Dinan midpipe w/VC, NW Carbonhaus CF, AST Springs, FC Spacers...more to come!
2016 Indi F80 M3 - SMB|Amaro | Mode Carbon | ESS | Akra EVO | KW HAS...SOLD 2012 MR e92 M3 DCT, ESS SC, Brembo BBK, BBS FI... GONE but not forgotten! 2008 AW e92 M3 6MT, ESS SC, BBS LM's...SOLD! |
