2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Is 1.7% tire diameter difference acceptable for Xdrive?
      05-21-2023, 08:43 PM   #1
omar.ahmad0524
Drives: 2018 bmw m240xi
I track my car and ruined the fronts by running them at incorrect pressure (excessive sidewall wear). Rears look fine however and are currently at 4/32" tread depth remaining
Wheels are stock and tires are Yokohama advan AD09 and tire sizes below with the new tire diameters as well.
Front : 225/40/18 (25.1")
Rear : 245/35/18 (24.8")
I want to see if I can safely change only the fronts since the rears look fine. The rears are at 4/32" tread remaining.
If I replace the fronts that means my front diameter will be 25.1" and the rears will be at (24.8 - 4/32) = 24.675".
This is a difference in diameter of 1.72%.
Is this fine for Xdrive vehicles? I track my car once a month in case the usage makes a difference.
      05-21-2023, 10:38 PM   #2
Fiesta ST to M240i
Drives: 2018 M240i
4/32" isn't a whole lot of tread. Could even get sketchy in heavy rain. I'd just get 4 new tires. Even if it is alright, why do it? You're just going to need new rear tires not too far down the road then you'll have mismatched wear again.
