05-02-2023, 10:56 PM | #1 |
Rep 33
M240 19 rims changed wheel size, consequences?
Hi guys I switched stock rear 245/30/19 to 245/40/19, do you think anything bad might happen? It fits fine no rubbing so far, but read transmission might suffer/go bad. I live in pothole city that is why I did this.
Diameter goes up 7.7%, 630mm-678mm. I could fall back to 245/35/19. ty. Last edited by empyrean; 05-02-2023 at 11:14 PM.. |
05-03-2023, 07:52 AM | #2 |
Rep 28
Drives: 2019 230i, ZHP, 318ti
You should be fine going up a size like that, although I wonder if a small upsize will help much with potholes. Let us know. Have you calculated the difference in your speedometer and odometer readings?
05-03-2023, 09:15 AM | #3 |
Rep 33
I kept 225/40/19 in the front. Feels much better than RunFlats. 3 days no issues lol.
No clue in how to check odo readings, I know it might change 5%, no real quantitative speed limit enforcement over here. ty |
05-04-2023, 11:12 AM | #4 |
Rep 55
Fire up the Waze app and compare your speedo to the GPS speedo at several speeds. I found that my speedo, in stock form is correct up until about 40mph then it starts going off by about 3%. if my speedo says 80, im actually doing about 77mph.
05-07-2023, 04:32 PM | #5 | |
Rep 410
You now have 2.36% difference in circumference F <> R But with 245/30 you had a 5.24% difference F<>R That would probably sooner or later destroy the XDrive if you have that. Otherwise .... |
05-10-2023, 11:14 PM | #6 | |
Rep 33
Original OEM setup: Front: 225/35 R 19 Y Rear: 245/30 R 19 Y My current setup: Front: 225/40 R 19 Y Rear: 245/40 R 19 Y wdyt? |
05-11-2023, 12:56 AM | #7 | |
3626
Rep 3,592
A few people who have swapped differential ratios without recoding (with typically 10% change in rear ratio) have run into driveline malfunction issues in some cases as the DME calculated gear ratio has not matched the wheel sensor measured speed, leading to false detection of continuous wheel slip and consequent error conditions. |
05-11-2023, 09:38 AM | #8 | |
Rep 33
aerobod3625.50 |
