2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes M240/235 sway bars on 228/230? and sway bar sizes
      04-25-2023, 11:36 AM   #1
BHR388
Drives: bmw
I have a 230 xdrive want to upgrade sway bars just did dinan springs and bump stops body roll has improved want to go one step further now
do the front and rear sway bars from a M240 fit the 230 xdrive? im looking at pics online and it seems that the 230 xdrive have a single hump off to one side of the front compared to it being straight across for the 240 and 235
Also what are the sizes of the stock bars? is the 240/235 RWD rear bar bigger than the xdrive 15mm compared to 13mm dinan also lists the front of the X drive bigger than the RWD 23.6 vs 22.2
https://www.ebay.com/itm/28415250243...temCondition=4
https://www.ebay.com/itm/28467497307...temCondition=4
      04-25-2023, 12:45 PM   #2
freakystyly
Drives: F22 B58 6MT
The Xdrive bars likely aren't bent strangely for looks. IMO just look for an aftermarket solution for your specific engine / drivetrain you know will fit which will include the correct size bushings and brackets. If you aren't DIYing, expect a hefty labor fee for the bar install.
Size doesn't always equal stiffness either, some bars are solid, some have heavier tubing.
This thread from the 3 series side may give some pointers... https://f30.bimmerpost.com/forums/sh....php?t=1418092
BHR3889.00
      05-27-2023, 08:35 AM   #3
LanceM26
LanceM26's Avatar
Drives: BMW M235i, BMW M240iX
Are you looking at a 240 xdrive sway?
