2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Weird alert when starting the engine
      04-19-2023, 12:39 PM   #1
MarcoZandrini
Drives: 2018 M240i
I went to start the engine (the engine was hot) and I received an alert in the gauge cluster (bottom right) and on the idrive. Basically they were telling me my key had an issue and that the engine wouldn't start. The engine started anyway. I shut off the engine and restarted the engine without issue. Any ideas? The key battery is about 6 months old.
      04-20-2023, 04:32 PM   #2
Kernel Kurtz
Kernel Kurtz's Avatar
345
Drives: 2020 M240i xDrive
This happens to me very occasionally (and did in my previous BMWs as well). I suspect it is an artifact of a temporarily bad fob signal for whatever reason. I think it can be safely ignored, that has always worked for me. If it happens all the time then it probably is your fob battery.
      04-21-2023, 07:16 AM   #3
MarcoZandrini
Drives: 2018 M240i
Thanks for the response. I replaced the battery in both of my fobs last fall. The first batteries failed within 5 days! Had bought them from amazon. Found out that they were counterfeit. Replaced them with reputable batteries.
      04-21-2023, 09:21 AM   #4
freakystyly
Drives: F22 B58 6MT
Same happened to me when I used some generic amazon fob batteries. The fob could still unlock from 300 feet away but wouldn't recognize the key when sitting in the drivers seat.
nazali1309.50
      04-21-2023, 12:06 PM   #5
MarcoZandrini
Drives: 2018 M240i
Good to know. Thanks!
      04-21-2023, 01:12 PM   #6
Kernel Kurtz
345
I buy a lot of stuff from Amazon, but batteries are one thing I definitely avoid there.
      11-13-2023, 08:31 PM   #7
ferntrouble
Drives: Camaro ZL1
Same to me.
      11-21-2023, 01:33 PM   #8
nazali
nazali's Avatar
Drives: 230 2020 vert F23
same here, I at times get that, more on the 1 series not on the 2, I think it's something to do where the fob is, if it's in your pocket near a phone it blocks it
as for batteries, I use Amazon stuff inclduing batteries. I got a pack of sealed OEM Panasonic batteries NO problems, in date and works fine
      11-21-2023, 01:35 PM   #9
nazali
nazali's Avatar
Don't use generic, use a named brand, Panasonics are totally fine
Most batteries like other things are made in the same sweatshop in China and they just slap a different sticker/badge/name on it
      11-22-2023, 06:13 AM   #10
freakystyly
Drives: F22 B58 6MT
Used Engergizers this time around and still only got about a half year of daily use before the fob was having troubles at the ignition. I wonder if it could be my main battery being weak too. It might need replacing this winter.
