04-13-2023, 12:45 PM | #1 |
Rep 12
N55 money shift over-rev inpa
Struggling with this...Hard...Can anyone give me some instructions on how (utilizing INPA) I can find the max engine speed record?
Background: 2015 M235i with a 6 speed manual. Pretty sure it was money-shifted and spun the crank hub. I need to see the max engine speed record...But it isn't immediately apparent on how to do this with INPA. Any help would be appreciated. Chris |
04-13-2023, 01:36 PM | #2 |
Rep 5,364
Not sure this is possible. A spun crank hub on a 6MT N55 certainly sounds like a money-shift. An over-rev report won't provide much insight into potential damage. It's pretty safe to assume that in order to spin the hub, it was likely a 3rd to 2nd gear near redline shift. That means the rpms likely went to 9000+.
You can reset the hub and retime the engine and hope for the best. I'd probably scope the cylinder bores first to see if any of the pistons kissed the valves and also check the oil and oil filter for metal. If there's metal, then you're looking at rod bearings too.
Wheelwright462.50 |
04-13-2023, 02:28 PM | #3 | |
Rep 12
Max engine speed record
In the past with older E models, this would probably end up in a HEXIDECIMAL format and need to be converted...Newer F/G cars would actually show the RPM's. Once upon a time, this might have been labelled as n_h_max in the DME or it could also be found under 0x7FABCE under MEMORY and RAM in INPA--I think....This is all of the information I've been able to scrape together (rather than just asking for help). Bottom line: this info IS in the DME and isn't something that gets erased when you (simply) clear codes. It's in non-volatile form within the DME and CAN be accessed....But only with INPA. Anyone? |
05-30-2023, 03:27 PM | #4 |
Rep 12
N55 overrev report max engine speed inpa
I will pay someone $500 cash if they can get me an overrev report for this car....In the Los Angeles area. Please message me.
