03-11-2023, 11:21 AM | #1 |
Rep 1,146
12mm Wheel Spacers
20 230 vert f23 stock !
12mm wheel spacers ? Is there a fitment guide anywhere. I'd heard that wheel spacers can damage/or invalidate warranty, cause issues down the road Your thoughts pls I've seen Bonono's (sp) I'm guessing get the best money can buy txs |
03-11-2023, 03:19 PM | #3 |
Rep 1,146
Hey,
txs for quick response, yes to hub centrics, I was actually thinking of putting the bolt conversion, you know the screw in studs at the same time. and yes I wanted to do just the back, mainly for the look, yes. |
03-11-2023, 08:28 PM | #5 |
Rep 1,146
03-12-2023, 08:46 AM | #6 |
Rep 51
I went with Burger Tuning 12mm spacers in the front and rear (they include longer wheel bolts) for my square OEM 18x7.5 +45 wheels during the winter. There is plenty of room and I probably could have gone 15mm all around easily; I am not lowered which could make a difference if you are.
Since you're staggered you may want to run the specs here (https://www.1010tires.com/Tools/Wheel-Offset-Calculator) and make sure you have enough clearance, but it's probably fine as others have mentioned. I would absolutely get the longer wheel bolts to match the spacer, anything over 3mm always get the proper bolts to match - even at 3mm I probably would because that's just how I am.
2019 M240i Convertible
- Mineral White/Cognac Interior - 034Motorsport P34 Air Intake/Remus Axle-Back Exhaust/M-Performance LSD - BimmerWorld TA5R - 18x8.5 +38/Michelin PS4S 235/40/18 Square |
nazali1305.50 |
03-12-2023, 11:31 AM | #7 |
3621
Rep 3,590
One thing to ensure with spacers is that the chamfer on the back is sufficient to allow the spacer to sit flush on the hub and the hub-centric boss sits inside the wheel centre hole without touching the chamfer.
This can be tested by inserting a piece of paper between the clamping surfaces and ensuring it is gripped all the way around the circumference. If the spacer rocks in any way against the hub or wheel mounting surface, do not use it. During a track day in 2021 we had a brand new M2 lose a front wheel at 160km/h when all the aftermarket studs sheared (luckily limited damage and no crash). At first it was thought there had been a bad batch of studs, but it was eventually tracked down to the spacer chamfer and the spacer not sitting flat on the hub. |
03-12-2023, 12:53 PM | #8 | |
Rep 3,496
James Clay of Bimmerworld created a video to demonstrate it: https://www.youtube.com/watch?v=lK0bzjInqWU.
03-12-2023, 02:22 PM | #9 | |
Rep 1,146
txs, good info, i'm not staggered, square setup.
just think looks better on rear, but hey still not sure Quote:
03-12-2023, 02:32 PM | #10 | |
Rep 1,146
wow, thats aero for bringing this up, I was finding it hard to picture the paper test and why, this one dradernh is fantastic
awesome txs this NEVER comes up, your right, never seen it on any YT vids Quote:
03-13-2023, 07:12 AM | #11 | |
Rep 51
I've personally never had issues when pairing OEM wheels with hub-centric spacers designed for a particular OEM and followed their guidelines, but there is no reason not to verify compatibility with the paper test. I suspect many chamfer issues occur when pairing aftermarket wheels with hub-centric spacers.
03-13-2023, 09:49 AM | #12 |
Rep 1,795
Possibly different hub lip sizes but this is from the F30 side. https://f30.bimmerpost.com/forums/sh....php?t=1387467 Picture shows a 12mm lip.
It's definitely worth double checking they mount correctly before you just throw them on and assume everything is fine. Last edited by freakystyly; 05-21-2023 at 12:32 PM.. |
