01-09-2023, 12:41 PM | #1 |
Rep 59
Drives: BMW 220D F22, Mazda MX5 ND
Whiteline Camber Bushings?
Hello all,
I tried to use Millway Street camber plates for my 220d with ST XA coilovers, but it made a lot of noise on the road. I guess ST XA and Millway can't work together. So i am searching for other solutions, such as front lower arm bushings. Powerflex seemed to be good quality but it only gives -0.5 max camber. I found these Whiteline camber bushings, they claim that it gives up to -1.5 camber, which is very nice for just bushings i think. What you think about those? Anyone used it? Also would you recommend any other solution to reach -2.5 camber? Thanks! |
01-10-2023, 08:49 PM | #2 |
Supreme Allied Commander
3837
Rep 54,338
Drives: F80 M3
Whiteline makes great suspension upgrades. Most lower control arm or bushings will only add around -0.5. The double offset can add more camber.
Here is another option for a wide range of camber adjustment, but NVH should be expected: https://www.hpashop.com/SPL-Adjustab...L-FLCA-F3X.htm Last edited by HP Autosport; 01-11-2023 at 12:35 AM.. |
01-12-2023, 11:36 AM | #3 | |
Rep 59
-1 of course wont be enough for track use, but it is better than 0 i guess. What type of NVH is expected with those arms? Camber plates were nightmare to me, it was installed uncorrectly i guess. If it is not that bad for daily and the joints wont be ruined after 30-40k km, it wont be a huge issue for me. |
01-12-2023, 12:31 PM | #4 | |
3837
Rep 54,338
Drives: F80 M3
Any spherical will require replacement at some point. Our recommendation for a street car is the Whiteline for a street car and Vorshlag plates for a track car. Track car that needs anything behind -3.0, then we recommend installing the SPL adjustable lower arms as well. |
01-13-2023, 01:38 PM | #5 |
Rep 59
[QUOTE=HP Autosport;29727745]Our experience with Vorshlag plates are a slight increase in NVH(expected with any camber plates), but there is no clunking unless something didn't fit or installed correctly. Vorshlag also uses the largest spherical bearing in the industry , more than sufficient to take the load.
Any spherical will require replacement at some point. Our recommendation for a street car is the Whiteline for a street car and Vorshlag plates for a track car. Track car that needs anything behind -3.0, then we recommend installing the SPL adjustable lower arms as well. Thanks a lot I am driving my 220d both daily and for 6-7 track days per year. This is why i want to have around -2 camber. Do adjustable lower arms worn out quickly? |
01-13-2023, 03:52 PM | #6 | |
3837
Rep 54,338
Drives: F80 M3
[QUOTE=omerakz;29731670]
That said, we still recommend camber plates for your application. |
