2Addicts | BMW 2-Series forum Technical Topics N20 (228i) / B46 (230i) Engine, Transmission, Exhaust, Tuning Used/Remanufactured N20 Recommendations?
      11-01-2022, 04:09 PM   #1
zach98
Drives: F10 535i
Does anybody have any recommendations where to buy a used/remanufactured N20 engine?
Some places I've been considering...
  • Ghassan Motorsports
  • LKQ Online
  • ProjectMMotors.com
  • BuyUsedEngine.com
  • Miami Engines LLC
  • AAAEngine.com
  • Ebay
Does anybody have experience with any of these companies or any other suggestions where I could get a decent N20? I'm leaning toward Ghassan Motorsports or Project M Motors at this point.
      11-03-2022, 02:17 PM   #2
ScottSmith
Drives: BMW E46 N20
car-part.com is an aggregator for dismantlers. You can sort by distance. I always check AWD and RWD since it's just an oil pan swap, though RWD is usually cheaper. I also check N20 and N26 since for my purposes they're equivalent, and the N26 is usually cheaper. For a street car swap I think you have to swap the fuel supply line and figure out what to do with the valve cover air line that goes to the air intake somewhere.
Also be careful about getting a 20i instead of a 28i motor. The equivalency database that car-part and therefore a number of dismantlers use says they're the same. They aren't. I don't think there was ever an N26 20i motor which makes that route a little safer. You can tell by the etching on the block: https://f30.bimmerpost.com/forums/sh...62&postcount=5
