10-05-2020, 05:17 PM | #89 | |
Rep 487
Hi, I'm also looking to get these because they offer stock ride height with zero lowering. Can you please confirm that's the case? |
10-05-2020, 06:11 PM | #90 | |
Rep 301
Drives: BMW M235i
10-05-2020, 07:03 PM | #91 | |
Rep 487
https://www.ecstuning.com/b-modular-...2cp-space-~ms/ There's no info regarding whether these are firmer than stock. Or if so how much.... I'm also wondering if these are on par with OEM quality. I don't wanna put just anything on. |
grocerylist268.00 |
10-06-2020, 02:05 AM | #92 | |
Rep 132
As opposed to: I've only driven MSS' M140i for 15 minutes, but it was less firm than my M235i with M Performance Springs and Bilstein B4 Damptronic shocks. Probably not a fair comparison. .... found more detailed instructions PDF (see attached PDF) it appears the adjusters are made by Aalco in Southampton: www.aalco.co.uk .... for those with an M240i and possibly M235i(?) there appears to be two different part numbers for F22's. F22's: 02aBMW2F22CP (F22 - Coupe) 02aBMW2F23CB (F23 - Convertible) https://www.mlperformance.co.uk/prod...wering-springs "If you have a M240i, we would recommend the MSS BMW F22/F23 M240i Height Adjustment Ride Management" F22 M240i's: 02aBMWM240CP (F22 - Coupe M240i) 02aBMWM240CB (F23 - Convertible M240i) https://www.mlperformance.co.uk/prod...wering-springs and.. F20/21's: 02aBMW1F20HB (F20 - 5 Door Hatchback) 02aBMW1F21HB (F21 - 3 Door Hatchback) F21 M140i's: 02aBMWM140HB (M140i - 3 Door Hatchback) Does anyone know what the difference is? Last edited by Matthewricha; 10-06-2020 at 07:52 AM.. Reason: Different F22 numbers and instructions |
10-06-2020, 09:35 AM | #93 | ||
Rep 487
10-06-2020, 10:01 AM | #94 |
Rep 132
I bought them second-hand (but checked at ETK for compatibility with my car), but if you can't buy them from a dealer you can buy them from here:
https://www.schmiedmann.com/en/produ...1-33-6-860-630 https://www.schmiedmann.com/en/produ...3-53-6-860-619 MP Springs (for my car): 31 33 6 860 630 33 53 6 860 619 Interestingly for M240i's I found that ETK showed that only the front springs are to be changed for M Performance springs option (SZP5A). European RHD, 2WD: M135i std Springs: 31 33 6 851 921 & 33 53 6 851 928 MP: 31 33 6 860 629 & 33 53 6 860 619 (Passive only) M235i std Springs: 31 33 6 865 634 & 33 53 6 865 637 MP: 31 33 6 860 630 & 33 53 6 860 619 M240i std Springs: 31 33 6 865 635 & 33 53 6 865 637 MP: 31 33 6 860 630 (Front only!) 31 33 6 860 631 if ZP Auto M140i std Springs: 31 33 6 865 634 & 33 53 6 865 638 MP: 31 33 6 860 630 & 33 53 6 860 620 Apologies for being off topic Last edited by Matthewricha; 10-06-2020 at 10:35 AM.. |
10-06-2020, 12:58 PM | #95 | |
Rep 487
10-06-2020, 02:04 PM | #96 | |
Rep 132
If you have black springs they are the M Sport, if they are Red they are the M Performance Springs. Your dealer is most likely getting confused between Sport and Performance. Last edited by Matthewricha; 10-09-2020 at 10:04 AM.. Reason: Clarification |
02-01-2021, 10:57 PM | #97 | |
Rep 337
You mind giving an update on how the car handles now? You on stock dampers and sway bars? Still deciding on pulling the trigger on these for my M240i. I'm on stock dampers. Do you think the MSS springs are much stiffer than stock? The stock rear springs are stiff from factory which I like. But, the front springs are way too soft. I'm hoping the front MSS springs are much stiffer. Rear can be stiffer too. I'm wondering if dampers will wear out faster and should replace at the same time. Only 29k miles on them though. Still feel new. Thanks |
02-03-2021, 10:25 PM | #98 | |
Rep 152
02-10-2021, 11:09 AM | #99 | |
Rep 337
Anyone else with details on how the MSS springs changed the driving dynamics on M240i/M235i? |
daneagles7.00 |
11-30-2021, 09:47 AM | #101 |
Rep 190,797
Im running the MSS adjustable springs on the G82 M4 Comp, I'm very happy with the ride quality
01-14-2022, 04:03 PM | #102 | |
Rep 444
And what camber plates are you on? Did the MSS springs have any interference?
01-16-2022, 08:33 AM | #103 |
Rep 376
The reference to hub swap and camber plates was to my 1 series track setup. I have had no issues with clearance on my 228 with the MSS spring even running the 245/275 setup. No rubs anywhere.
Past: 1979 RX-7, 1980 Civic, 1989 B2200 lowrider, 1990 Golf GT, 1995 Civic Si Turbo, 2000 Civic SiR, 2000 328i, 2003 540i M-Sport, 2008 Rabbit, 2014 Pilot, 2002 A4 1.8T, 2009 A4 2.0T Quattro, 2017 CR-V Touring 2020 CR-V Touring
Current: 2012 135i, 2015 228i x-Drive, 2023 CR-V Touring Hybrid |
09-23-2022, 02:08 AM | #104 |
Rep 8
I pulled the trigger and ended up getting Vorshlag camber plates and Turner front and rear sways bars with SPL end links. I can now really pitch the car really hard when taking turns. It is quite a nice set up. My alignment is now really good before I had some tramlining. It is completely gone. I have them set at stock height and it still clears my drive way and there is massive improvements its night and day. I may get some more SPL parts, bushings, and new Bilstein B6's. Can't wait till a track day at Big Willow.
06-03-2023, 05:18 PM | #105 | |
Rep 38
