2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions BimmerCode
      01-01-2022, 05:03 PM   #485
Maxim85
Poland
Drives: BMW F46
Hello there,
I am sorry if that question was asked billions of times. I am quite new in BMW society, thus…
Does bimmercode work with any OBD II adapter or it requires to buy recommended kit on their webpage?
nazali1309.50
      01-18-2022, 07:12 AM   #486
BRTK.
Drives: BMW M240xi
Originally Posted by Poochie View Post
That can't be done with Bimmercode, you need a more invasive program like ESYS to access the EDC module.
I was wondering how ESYS would compare with protools. Anyone have experience with this ?
      01-18-2022, 09:05 AM   #487
MarcoZandrini
Drives: 2018 M240i
Originally Posted by Maxim85 View Post
Hello there,
I'd check the bimmercode website to see what adapters are recommended.
      01-18-2022, 06:52 PM   #488
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
Only ESYS would allow such a change, BimmerCode, by nature, doesn't grand access to the module necessary (EDC).
nazali1309.50
      01-19-2022, 07:46 AM   #489
BRTK.
Drives: BMW M240xi
Yep, bimmercode is less advanced than protools. Protools claim you can access every module of the car, so it should be pretty much the same as esys.
      01-20-2022, 12:41 PM   #490
nazali
nazali's Avatar
Drives: 230 2020 vert F23
on the bimmercode page, there is a whole list of adaptors
I used the bluetooth one CX something or other,
but I got mine of amazon
it was cheaper
Hello there,
      01-21-2022, 07:03 AM   #491
abo7maid
Drives: BMW 740Li G11/G12
How did you guys manage to code via BimmerCode ..
-Show current gear in dash,
-Door handle lights on during reverse, or the welcome carpet light on reverse,
and could anybody help to fix the issue with my Headunit option on BimmerCode that it always says "Error while reading coding date" which I used to be having third party CarPlay that it's been removed right after the last update by the dealer.
      01-21-2022, 12:56 PM   #492
sl0w_N55
sl0w_N55's Avatar
Drives: 2015 Bmw M235i x-drive
Originally Posted by SwolePatrol View Post
Just used this app on my iPhone to make the following changes:
-Auto-Fold Mirrors on comfort touch lock/unlock
-Windows/Mirrors/Sunroof open/close with FOB
-Legal disclaimer removal
-Ambient lighting 100%
-DRL 100% at all times
-Digital Speedometer
-M Performance iDrive Startup
-M Performance BC startup
I would highly recommend this app to anyone. It was super easy to utilize and backs up your settings in case you need to revert your changes.
Probably the best $30 (App) and $12 (OBDII Adapter) spent!
For some reason only my passenger mirror folds in automatically. Is there not a motor on the drivers side?
sl0w_N55
-MHD stage 2
-Jordan Carry custom e85 tuned
      01-21-2022, 02:54 PM   #493
jzeiler4
jzeiler4's Avatar
Drives: 2021 M240i xDrive vert
If one folds then they both fold unless the motor has gone bad in the drivers side mirror.
      12-27-2022, 08:14 PM   #494
lucac7
Drives: Bmw M235i
2016 BMW M235i  [0.00]
Originally Posted by danielduke View Post
Hi everyone,
I did some codings to my f22, one of which I'm a little bit concern is that I enabled the digital speed indicator, but when I did that I noticed that the temperature that is displayed in the instrument cluster is crazy and also I did the coding whit a full fuel tank so now i'm getting a range fuel number very high and different as when I started coding.
Anyone can help me with this issue?
Thanks
Did this issue fix itself? Just coded the digital speedometer and my fuel range went up from 170 to 230 miles.
      03-14-2023, 07:43 PM   #495
LanceM26
LanceM26's Avatar
Drives: BMW M235i, BMW M240iX
Does anyone know how to stop the car from shutting off even when in accessory mode when exiting the vehicle?
      03-15-2023, 03:22 PM   #496
jzeiler4
jzeiler4's Avatar
I exit the car all the time with the engine running. But my guess is you mean after you have shut off the engine you want the ignition to stay on?
      03-16-2023, 01:06 PM   #497
LanceM26
LanceM26's Avatar
Yes, in parking light mode with my engine on... the low beams are also on. But when the engine is off, the low beams are off. When I want to take pictures with the angel eyes on, I want to use parking light mode since it is dimmer.
      03-16-2023, 08:44 PM   #498
jzeiler4
jzeiler4's Avatar
Just turn the lights off with the engine running and you will still DTR going (angel eyes). That is unless it is a Canadian thing with the lights. You can set the brightness level for the DTR in the iDrive.
      03-17-2023, 12:33 AM   #499
LanceM26
LanceM26's Avatar
Yea, I can do that. I was just hoping there was a way to have the car not idle since PCV issues arise on B58 when idling. I found a workaround for now. You can put the car into parking light mode while it isn't on ACC or Ignition mode. I can't find the setting for DTR brightness in iDrive, and the BimmerCode option for changing DRL doesn't change anything for me.
      03-17-2023, 03:07 PM   #500
EddieMorra
Drives: 2015 328i
Hey curious if anyone has had success coding LED turn signal’s recently? I bought LASFIT LED bulbs on Amazon and they fit right they have the correct 180 degreee offset, and they light up. But the car has all these malfunctions with them. I bought bimmercode hoping I would be able to fix it but even after coding them as LEDs the car still throws error codes.
The weird thing I noticed is the malfunction will only start when it’s dark enough outside. If it’s daylight they seem to work okay. So something about the auto trigger for night time gets them to act up. The whole car dings repeatedly and lighting malfunction won’t go away.
      03-26-2023, 03:08 PM   #501
bensanford
Drives: Grey '18 230i & Grey '21 330ix
Start Logo display?
There is an option for the Start Logo in the instrument cluster, and Bimmercode doesn't allow me to set the correct display. (this might not be a Bimmercode issue) It is an option for in the instrument Cluster options under KOMBI_CT_RD1 that says "Display Options Instrument Cluster" - Start logo, and it allows selection for various start logos - however there is not an option for 230i. Available options in my f22, 230i are: 50d, 135i, 140i, 235i, 240i, 340i, AG, M Performance, MW, MW Competition, M2 CS, M3, and M4. I've user Bimmercode with no issues in the past, with no issues, but don't understand the lack of an option to display what matches my car.
__________________________________________
'18 m230i, Mineral Grey, MT, M-sport, Track Handling, Premium, H-K audio, CarPlay, no Moonroof,
'21 m330ix, Mineral Gray, Navi, Driver Assist, Park Assist, 19' orbit grey wheels (wife's car)
      03-27-2023, 08:55 AM   #502
jzeiler4
jzeiler4's Avatar
It is not Bimmercode's issue but rather what is available on your Kombi unit.
      03-28-2023, 05:28 PM   #503
alanchicken
Drives: M240i
Hello guys, I am pretty new to coding. Is Bimmercode able to code android screen mirroring? Thanks.
      04-10-2023, 01:15 PM   #504
tcollier91
Drives: M240i
I've had my car coded for a while now. I just got a new clutch installed, and they unplugged the harness so the car doesn't know what gear it's in (disables rev matching) but unfortunately this also disables my PDC when I go into reverse. I can hit the PDC button, but then I also have to hit the camera button on the screen to have my rear view camera turn on. Is it possible to have the rear view camera on automatically when I hit the PDC button? I have turn camera on in reverse activated, but since the car doesn't know what gear it's in this doesn't work. Really enjoying having rev match disabled though.
