2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Went LCI guage cluster, can I go back?
      05-24-2024, 07:49 PM   #1
TonM3
TonM3's Avatar
Drives: 2006 E46 M3 / 2017 M240
I put in an LCI guage a 2 years and 3000 miles ago. It worked fine the whole time but now is glitching badly. Turns off completely for a few seconds.
I'm assuming the issue is in the cluster so I want to put the original back in.
Since I had to get some programming done for the LCI, do I need to do any to go back to my old cluster?
E46 -> E90 -> F30 -> F23
      05-25-2024, 02:06 AM   #2
llebnave
Cadet
llebnave's Avatar
13
Drives: 2017 M240i, 2007 335xi
Yes, I can confirm it is perfectly safe to swap back to your original cluster. The KOMBI control unit is located in the cluster itself, so the coding will be in the same state as it was when you removed it, and the odometer will update to the current mileage once it is reinstalled. No additional coding or programming is necessary.
TonM3253.00
      05-25-2024, 03:52 PM   #3
TonM3
TonM3's Avatar
Thank you. So just confirming that Even though I had to do programming for the LCI cluster, I don't have to do deprogramming for the old old cluster.
      05-25-2024, 03:57 PM   #4
llebnave
Cadet
llebnave's Avatar
13
Yes that is correct 🙂
      05-25-2024, 04:01 PM   #5
TonM3
TonM3's Avatar
You rock. Thank you.
I hope that the issue is a fault in the cluster and nothing else.
Do you know if I can put in another virginized LCI cluster down the road with no programming also?
      05-25-2024, 04:22 PM   #6
llebnave
Cadet
llebnave's Avatar
13
Yeah fingers crossed for you, hopefully it is isolated to just that.
If you get a new one, I expect that you would need to have the programming done on that one when you first install it. After it has been done once though, it is paired with your VIN and would need to be virginized again to be disassociated.
      06-02-2024, 11:22 PM   #7
TonM3
TonM3's Avatar
Put the old cluster in. The functions of the cluster all seem to work but several other things don't. I can't set the clock or date and the fuel economy is not coming up in the idrive only - -.
      06-04-2024, 06:10 AM   #8
llebnave
Cadet
llebnave's Avatar
13
Curious, that sounds like the headunit, but that's just speculating. You may want to reach out to your coder after all, I apologize 🙁
      06-08-2024, 09:41 AM   #9
TonM3
TonM3's Avatar
Big shout out to Steve from codemybimmer who remotely coded back in the pre LCI cluster in just a few minutes.
Search this Thread:
