2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Center channel upgrade?
      10-01-2015, 10:08 AM   #1
ggabriele3
Drives: 2015 228i Msport
In preparing for my speaker upgrade I've read a lot of posts about people disconnecting their center channel speakers, and also saying it can't be upgraded easily because the space under the speaker is small and shallow.
However, it appears that there is a lot of space above the speaker:
so, seems like a spacer could be crafted to make a better speaker (is go with the focals) fit. I'd be designing and 3D printing the spacer (see my other thread).
Would it be worth the upgrade?
      10-01-2015, 10:46 AM   #2
Viffermike
Viffermike's Avatar
Remove the speaker, ggabriele, and take note of the small 'cup' beneath the OEM speaker's magnet structure. Anything aftermarket with a decent-sized magnet likely wouldn't fit with the proper clearance, even with a spacer. Basically, one would need to carve out the cup, then figure out how to isolate the speaker enough to get decent sound out of it.
The exception to this that I've seen is the BAVsound driver for the F30. I'm not sure that it's a drop-in fit for the F22, though. From what I've heard, the dimensions are slightly different.
--Helmets are for closers.--
      10-01-2015, 10:57 AM   #3
ggabriele3
When my Focals arrive I'll see what the magnet area looks like. It looks like there's at least 20mm of clearance between the speaker and the dash, maybe a thick spacer would work.
Maybe a few extra mm of clearance could be bad if I go with a component speaker instead of a coaxial, since there's clearly a spot to the right where a separate tweeter could be mounted (I assume that's what the HK system does)
      10-01-2015, 11:06 AM   #4
akuan99
Drives: 2015 228i M-Sport Track 6MT
The issue with replacing center speaker is limited clearance for speaker magnet and basket.
Before working on an adapter you should just place replacement speaker over center cavity and see if front frame of speaker stays below dash surface.
Also removing center speaker sounds better IMHO.
It makes sound stage much wider.
      10-01-2015, 11:51 AM   #5
Viffermike
Viffermike's Avatar
Correct. Both akuan99 and I have replaced our speakers and looked into the center-channel retrofit issue. The 'cup' I talk about fits the curvature of the OEM CC speaker fairly tightly, and appears to function somewhat as a baffle. Your issue isn't the 20mm of room from the speaker mount to the dash lip -- your issue is the plastic behind the mount, where the basket and magnet fit into.
In the F22 Hi-Fi system, the rear deck speakers and the center channel speaker are exactly the same, right down to the part number. The rear deck mounts have no baffle and no plastic underneath, so pretty much any 4-incher will fit. The opposite is the case with the CC.
      10-05-2015, 06:08 AM   #6
ggabriele3
This is incorrect, at least from an install standpoint.
The drivers appear to be the same, but the front speakers' mounting holes have a much larger diameter than the rears. As a result I had to design special adapters to mount the fronts in the doors.
See my post here: http://www.2addicts.com/forums/showt...0#post18691100
      10-05-2015, 09:14 AM   #7
akuan99
Front center speaker is not the same as L or R front speaker.
Center speaker is same as rear deck speaker.
      10-05-2015, 12:11 PM   #8
Viffermike
Viffermike's Avatar
Thank you.
For the Hi-Fi system:
Center Channel & rear deck: Part no. 65139169690
Front doors: Part no. 65139804157
This page on realOEM may help with part-number references, ggabriele.
      10-07-2015, 03:46 PM   #9
Geektechlive
Geektechlive's Avatar
Drives: 2022 M3 Competition
What is the center channel used for? Is regular music piped through that?
Owner of a 2022 M3 Competition AWD in Individual Voodoo Blue and Fiona Red leather
      10-07-2015, 06:19 PM   #10
OpenAir
OpenAir's Avatar
Drives: Enzo F23 228i
2015 BMW 228i  [0.00]
I would not remove the center channel, but would rather suggest that it be "padded" down with a 4~8ohm power resister. Having that speaker up high in the dash will raise your soundstage ever so slightly.
      09-29-2019, 11:50 PM   #11
Byeung
Byeung's Avatar
Drives: BMW M2
2018 BMW M2  [10.00]
Speakers
What is the point of disconnecting the center speaker?
      09-30-2019, 08:11 AM   #12
DistantTea
Drives: Oops
That center channel speaker is trash. It's an L+R mono combined channel so its just pointless and murders the sound stage. Disconnecting it results in a significantly cleaner sound stage. I'm pretty sure it's mostly there for ASD and for HK buyers to think they have something fancy. We don't. It's a trash speaker in a trash location that ruins music.
      10-09-2019, 04:56 PM   #13
Viffermike
Viffermike's Avatar
PREACH!
Just. Say. No. and YANK that thing OUT, stat.
If an audio system really wants to call itself a surround system, it needs to not simply combine stereo channels into a mono channel and call it a center channel, because that's not really a channel at all. That's like sticking a 1980s boom box in mono mode on the coffee table in the middle of your home theater setup ...
... which, by extension, wouldn't have time correction applied properly, either, because the sum-of-two-stereo-channels signal it gets hasn't had proper correction applied. That's what messes up the soundstage the most.
      10-24-2019, 05:00 PM   #14
ferraricare
Drives: 2016 M235i
2016 M235i  [0.00]
Non Audiophile's Take
I've read many posts about the issues with the HK system but due to my specific situation, I went a different route. I am not an audiophile and I mainly listen to spoken word (audio books, podcasts). So as improvement step one, l upgraded my center speaker. And to my ears, this has been a positive step up in sound quality.
      11-23-2019, 07:58 AM   #15
guigui92350
Drives: 118i M Sport Ultimate
+1
      11-23-2019, 04:14 PM   #16
Mehim
Mehim's Avatar
Drives: M240i xdrive
Just unplug it.
      11-24-2019, 01:16 PM   #17
MrOhnoez
Drives: '21 GLI, '79 beetle, '99 M3
I'm a little curious,
Why not put a spacer for the cup spacing, and reform/ get a custom top cover to allot it as a whole, to sit up higher.
      12-30-2019, 07:21 PM   #18
radio3
Drives: M240i
Does anyone have a photo of the cup showing what it is?
I was hoping to install a nice multichannel sound system with sophisticated technology to make use of a center channel. With the right implementation (i.e., processing) a center channel can greatly improve sound stage for other passengers in car. It’s really disappointing to discover here that that might not be possible? I was hoping to use Morel Hybrid 402s in all five channels.
      01-15-2020, 06:17 PM   #19
GeorgeR
Drives: 2016 X6 XDrve35i 2009 335i E92
Stating as an absolute a preference to disconnect the center speaker when doing a system upgrade is shortsighted.
I would agree if the OEM amp was retained or the replacement amp and added DSP wasn’t advanced enough.
I had my 335i center channel disconnected for example and since I am usually by myself when driving, the driver optimized tune works out perfectly and my wife doesn’t really notice how much better the system sounds when in the driver seat and how relatively bad it sounds in the passanger seat. Just the nature of the beast.
Interesting YouTube video from Andy Wehmeyer, owner of Audiofrog.
I know I have different BMW models but all BMW audio systems are very similar so while finalizing an upgrade for my X6 I have been browsing all forums in my research.
For the X6 I am having the new Helix DSP Ultra installed and programming two tunes, a 2-seat tune and a driver seat tune. The new Helix DSP Ultra has improved Virtual Channel Processing and adds some FX sound features including Real Center.
In order to maximize these newer capabilities, I will be upgrading all 3 pairs (FL/C/FR) of my front stage to identical mids and tweeters. If the DSP Ultra real center works as well as the pro level Brax, and it should, I won’t have to compromise enjoyment of the system sound stage to just one seat, both seats will have the same optimal experience and when I want, toggle to a driver seat tune when I am alone.
      01-23-2020, 02:10 AM   #20
bstone995
bstone995's Avatar
Drives: 2016 228i Cabrio (F23)
I installed the Eton B100XCN center speaker, made specifically for that purpose. It is a great little speaker and you can pick one up on eBay for about $100.
2016 BMW F23 Cabrio
- Burger Motorsports JB4
- MishiMoto Intake
- FlowMaster
      01-25-2020, 01:39 PM   #21
XutvJet
Is it completely plug and play; no modifications?
      01-27-2020, 02:49 PM   #22
OldCrow7xx
Drives: 2016 M235i Xdrive 8A
PREACH!
Might be a dumb question, but like do I need to disconnect the battery before un-wiring the leads onto tho back of the magnet? I really don't know how this stuff works. I would assume unless the stereo is ON it won't matter but wanted to be safe.
All I want is any semblance of sound stage, right now I feel like that car has absolutely none compared to my 3 series.
Thanks for any info you can provide!
2016 F22 M235 8A HK NBTevo | CTS HEX Intake | CTS Chargepipe | Gplus Intercooler | VRSF DP | BM3 Stage 2+ | 18" CSL Replicas | XHP X-Delete
Search this Thread:
