2Addicts | BMW 2-Series forum Technical Topics Tracking / Autocrossing Chassis Malfunction?
      09-06-2015, 09:42 AM   #1
ketema
Drives: 2015 M235i
Yesterday while at a test in tune day I was taking laps at the FIRM in Starke, FL and I came in too hot on a U turn and did not get my downshift to second completed in time. I was testing my new Toyo R888s which were phenomenal and so decided to try and re match and complete the downshift while in the turn. I of course initiated a spin. However I corrected and started a really nice drift. Then the car threw an error and completely cut power. The error was "Chassis Malfunction" moderate driving still possible. With the loss of power I just stopped, didn't finish the spin or anything. The car would not come out of normal mode although it was running fine. I came into the pits cycled the car and it was fine. I was driving as I always do in DSC Off mode and I have the KW EDC delete kit to go along with my club sport coil overs. So what causes this error? Obviously the spin, but why? I have spin before and this didn't happen. This was my first sustained drift though...man it felt good too! Thoughts appreciated
2015 6M Black Sapphire Metallic | MPE w/Carbon Tips | Digital MP Steering Wheel | Carbon Interior | StopTech Slotted Rotors | Pagid RSL1 Race Pads | KW Clubsport Coilovers | DINAN Stage 2 and Carbon air intake | Clutch Masters Lightweight Performance Clutch and Flywheel | Hotchkis Anti-Roll Bars | Enkei RS05RR 18" Racing Wheels
      09-06-2015, 09:48 AM   #2
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
might be a safety feature to prevent you from screwing/ overheating the diff or something.... same thing happened on a skid pad to me
      09-06-2015, 09:51 AM   #3
ketema
Drives: 2015 M235i
How do they make that drift commercial then? Using non standard cars? If so that's kinda bogus
      09-06-2015, 11:51 AM   #4
Pparana
Drives: 2015 m235i
drivetrain malfuction was more probably the kW delete modules getting too hot or the tune, no sensors on the diff.
My guess is the sensor wires, maybe get loose or the heat caused a pin to get loose. If you had a snap oversteer with correction may just have tugged a wire too far for a second, if it cycled away on restart and you don't see again I would not worry.
Only time I have seen was when I forgot to plug in one sensor after spring swap, and on tune when ran out of meth on track, my friend was driving he came in the pits white faced, he thought he blew the motor lol.
If does not repeat I would not sweat it.
      09-06-2015, 11:53 AM   #5
ketema
Drives: 2015 M235i
It wasn't drivetrain. Chassis malfunction.
      09-06-2015, 12:28 PM   #6
Pparana
Drives: 2015 m235i
Sorry, chassis is most likely the sensors then.
      09-08-2015, 08:36 AM   #7
Dinan_Engineering
Dinan_Engineering's Avatar
Drives: Any BMW
Without knowing the exact code this is purely speculation but I suspect the “spin” flipped out the yaw sensors and the car was trying to save lives……
Appreciate 4
      09-08-2015, 08:25 PM   #8
Pparana
Drives: 2015 m235i
Seems reasonable, every time I spun I stalled. I do not think you car totally defeat the traction control, I think it just starts dialing it back.
      09-09-2015, 05:29 AM   #9
verheizer
Drives: 435i
I read about a similar phenomenon in a german car magazine. I think it was a tuned 435i. When the EDC equipped cars get too much lateral acceleration this chassis malfunction mode engages. Nothing is broken, but it sure is annoying.
      09-09-2015, 05:30 AM   #10
ketema
Drives: 2015 M235i
I'd like to know if there is a way to turn it off? "Completely off mode"? Lol.
      09-10-2015, 11:54 AM   #11
caycep
Drives: 228i
2015 BMW 228i  [0.00]
hopefully it's not a "malfunction" in the same vein as when Houston mutters about "launch anomaly"'s
      09-10-2015, 01:38 PM   #12
Pparana
Drives: 2015 m235i
Chassis Malfunction, car on roof, drive moderately.
DVC558.00
      10-19-2015, 11:56 AM   #13
lijiahua790
lijiahua790's Avatar
16
Drives: 2012 328i n20
KW EDC delete
So what will be the solution here?
      10-19-2015, 12:04 PM   #14
ketema
Drives: 2015 M235i
Well for me it never happened off track. I attributed it to spinning and heat. Once the car cooled it was fine. I had it happen a couple more times on a different track, but each time I was thrashing the car. So not sure why italics happen to you unless you were doing the same.
      10-23-2015, 10:45 PM   #15
Pparana
Drives: 2015 m235i
You could add a heat sink to the module or place where they get some airflow. I do not have them, I just read that some other cars had issues with them overheating.
      03-28-2016, 06:07 AM   #16
gr8bone
'15 M235i xdrive kw clubsport edc delete chassis malfuction!
Hi 2 addicts this is my 1st post.
Mods:
Dinan stage 2 ecu, intake, exhaust
Front rear spoiler, black grill, black badges, M stripes on a white car.
Hoosier A7
All those mods were running fine for 5k miles.
As soon as i put on the kw clubsports with edc delete the car started up with chassis malfunction and has been driving in limp mode for the past two weeks.
I was hoping the error went away like it did for others on the forums but it didnt and i autocrossed it in limp mode which doesnt let me turn dsc off nor put it in sport+
I tried swaping the front vertical acceleration sensors and tried leaving them unplugged, neither worked.
What else can i try before taking it to the dealer?
      03-28-2016, 06:10 AM   #17
ketema
Drives: 2015 M235i
Mods:
Hoosier A7
I would check your EDC delete install first.
      03-29-2016, 09:18 AM   #18
Pparana
Drives: 2015 m235i
It is also possible to just code out the option, its pretty easy. I went that route as the modules tend to have heat issues.
      03-29-2016, 10:56 AM   #19
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
Had the same message the first time I started the car after installing JB4. Just turned the car off and back on and it never came up again.
Not sure if it was related to JB4, but it happened right after JB4 install.
      03-29-2016, 02:33 PM   #20
Pparana
Drives: 2015 m235i
if you disconnect the battery you will get it for the first few minutes of driving until everything relearns.
      03-30-2016, 02:25 PM   #21
gr8bone
It was my EDC delete. One of the pins was bent.
Straightened it out plugged it back in and everything is gr8 now!
Luckily i found it on the first wheel i tried
Thanks everyone
rich8566608.50
amw896582.50
      08-30-2016, 06:44 PM   #22
cbbplanet
Drives: space shuttle
hey sorry to bring up an old thread but i was wondering if you have a picture of your edc delete? i have the same exact chassis malfunction message
When i installed my v3, the shop actually had to cut the existing connector off and splice the new cancellation kit. I'm think thats the reason its throwing the error but can't really undo the splicing now.
