08-20-2019, 10:24 PM | #1 |
Rep 34
Any way to tell if M-Perf LSD is installed?
Hello all,
I've been looking at a 2014 M235i, and I have its VIN so I could check its features, but is there any way I can tell that the LSD is installed on the car? If not from the VIN, how can I tell if I go see it in person? Thanks! Jason |
08-21-2019, 12:48 AM | #2 |
Rep 129
In person inspection—look under the car. The LSD is a bulbous encased piece that mounts in the center of the rear wheel axel, in front of the gas tank/exhaust system.
I would imagine that since the LSD on the 2-series is a port install/retro fit (save M2's) any 2er with one would have it listed as a selling feature. |
08-21-2019, 06:08 AM | #3 | |
Rep 34
https://www.pacificmotors.com/wp-con...3697161369.JPG (Open diff) http://cdn.shopify.com/s/files/1/127...g?v=1536331208 (LSD) The car I'm looking at is a 6mt, apparently possibly a press car (I know I know, it's probably been beaten on), but I would imagine most of the M235i press cars have the LSD installed haha Last edited by JaZoN_XD; 08-21-2019 at 06:14 AM.. |
08-21-2019, 07:30 AM | #4 |
Luxury at the redline :)
9099
Rep 7,563
Look for the Drexler logo on the back of the diff to verify it has a MP LSD; the stock diff doesn't have this etching..
08-21-2019, 08:22 AM | #5 |
Rep 1,215
Drives: 2015 M235ix
Does the current owner claim that it has an LSD?
If not, then it most likely does not have one. If so, then ask for some sort of proof. |
08-21-2019, 10:40 AM | #6 |
Rep 34
Ah, this is cool, thanks a lot! I'm guessing there's no obvious signs other than small details like this then? Ideally, I would be able to tell by driving it, but I haven't really got another car to compare to :'(
08-21-2019, 11:32 AM | #7 |
Rep 469
Lift the car so both rear wheels are air born. Turn one of them in one direction. If the other rear wheel turns in the opposite direction it is an open diff. If the other wheel stops or turns in the same direction it is a LSD.
DD: F48 X1 xDrive25i '20 - https://f48.bimmerpost.com/forums/sh....php?t=1703083
For fun: F22 M240i '19 - https://www.2addicts.com/forums/show....php?t=1644646 Previous BMW: Fully loaded F30, 335i https://f30.bimmerpost.com/forums/sh....php?t=1681247 |
08-21-2019, 12:04 PM | #8 | |
9099
Rep 7,563
If had I not taken back the the old diff from the dealer, I would of thought they were trying to rip me off, based on their exterior's uncanniness to each other.. |
QuarterMileJoe9.00 |
08-21-2019, 12:51 PM | #9 |
Rep 1,241
There are also part number stickers on the outside to distinguish LSD from open diff. Might need to use a phone or camera/scope to read the numbers though. Don't recall if they are easily viewable once installed. The stickers look durable and semi-permanent so I don't think anyone would have a reason to remove them before installing. Look and you'll find one.
There likely won't be an option code for the LSD. You'll have to verify with external markings or go for a drive.
CP911
08-21-2019, 01:04 PM | #10 |
E4 Mafia
308
Rep 409
Drives: E30, E36/5, E46, F22, F30
Garage List 1990 BMW 325i [0.00]
1998 BMW 318ti [0.00] 2003 BMW 325i [0.00] 2015 BMW 335i [0.00] 2015 BMW M235i [0.00] |
burnout. leaves 11's, then you got one.
(jk)
Squad - '90 E30 325i MT (225k) | '98 E36/5 318ti MT (153k) | '03 E46 325i MT (152k)| '15 F22 M235i MT (60k) | '15 F30 335i MT (80k)
KIA - '91 E30 325i AT (146k) | '02 E46 325i MT (212k) Bring back the purple M stripe |
08-22-2019, 06:42 AM | #13 |
Rep 34
08-22-2019, 01:11 PM | #14 |
Love to Drive
197
Rep 602
08-22-2019, 01:18 PM | #15 | |
9099
Rep 7,563
And factually, Drexler only makes the LSD for BMW.. Why would their insignia be on a open diff unit, without a LSD.. Do you have a photo of both to back this claim? I don't have the car anymore.. Last edited by Poochie; 08-22-2019 at 02:30 PM.. |
08-22-2019, 01:55 PM | #16 |
Rep 117
If you accelerate hard in the middle of a turn with the windows down in a quiet area, you might hear a "chlunk" noise when it locks up. Parking garage would be ideal for hearing this.
08-22-2019, 03:12 PM | #17 |
msej449
506
Rep 715
Re. the part number label: Here is my original open diff unit after it was replaced by the BMW M Performance LSD ...
You'll see it has a part number label on it, which is like this Given it was on the car 2 years before replacement, through two UK winters and ski trips to the Alps, I'm guessing the label faces upwards, as it's in fairly good condition. Hopefully, it's possible to position a mirror/mobile in the gap between the diff and the bodywork so you can read off the part number of the diff that's fitted on the car. I'd contact your local dealer's service department and give them the VIN and ask what the part numbers would be for the standard and LSD units for your specific vehicle, as there is variation by model, year and auto/manual. But as mentioned, I'd expect the owner to have the documentation to hand. If they've retro-fitted the LSD some time after delivery (like me) they'd probably have the original diff as well.
2023 Peugeot e-208 GT (electric) Last edited by msej449; 08-22-2019 at 03:27 PM.. |
08-22-2019, 10:22 PM | #18 | |
Rep 436
In fact, about my only gripe about the expensive M-Perf LSD is that it doesn't have a nice M logo. For all that money it would be nice if it looked different. Something you could peak under the back and go "oooh, it has the LSD". I think the only way to really be sure is to check the part # on the sticker. And yes, it's up on top and a bitch to see when it's installed. I'm also not sure on the spin the wheel trick. I could swear the last time I had both wheels up I tried it, and they spun in the opposite direction. That behavior could be different based on the technology used in the LSD. This is a clutch based unit, so it may only kick in under spin/speed difference/load. A slow spin by hand likely won't activate the clutches and the regular diff in the middle will still do it's job. |
08-22-2019, 10:28 PM | #19 | |
9099
Rep 7,563
I verified that ZF Friedrichshafen AG supplies the front/rear differential for all BMWs, who is responsible for the final assembly of the system, both LSD or open diffs. So if you guys are supposedly correct, the million dollar question is why there is a Drexler logo on a part they have no connection with.. : I hate to mislead anyone with wrong information, so correct me if I'm mistaken with something verifiable that the stock diff has the same identifiable insignia in question. |
08-24-2019, 12:36 PM | #20 | |
Rep 448
Driving the two back-to-back also revealed noticeable differences, especially going up wet hills that are part of my daily commute. A mirror with LEDs is helpful for seeing the sticker once installed; something like the link below. A good tool to have in the kit in any case. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
10-04-2019, 03:51 AM | #21 |
Rep 72
I had the exactly same question and what I did was jacking up the rear of my car and do the spinning test..both spinned in the same direction, so LSD.
About the "Drexler" insignia in the LSD, the one with "2.2" is not their insignia. My LSD has it but my open diff (which I keep) has it too (with 2.2 too), I just checked it this morning. What I could not verify is the code reference of the LSD, as it is already mounted and Im only able to see the lower part of the differential. |
Brotherhef43.00 |
10-04-2019, 03:55 AM | #22 |
Rep 72
Where should be the sticker? In the opendiff is in the top side, so once is mounted is impossible to see it.
There should be a yellow sticker in the rear of the LSD (the part where the 2.2 insignia is)? |
