2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Speedometer
      08-20-2019, 08:30 PM   #1
Price695
Drives: Bmw 228xi
Is it normal for my speedometer to sit below 0 ?If not what can cause this and how can i fix it if its not normal ?
      08-21-2019, 07:35 AM   #2
makrop
makrop's Avatar
Drives: '18 M240i 6MT MGM/CR
Go faster!
18' F22 M240i | 6MT | MGM/CR
02' E46 325i | 5MT | SBM/B (beater - 200k+)
10' E82 135i | 6MT | BSM/CR (sold)
03' E46 330ci | 5MT | JB/B (sold)
lnoble15.50
      08-21-2019, 07:45 AM   #3
Price695
Drives: Bmw 228xi
Thanks ... but in all honesty anyone know ?
      08-23-2019, 06:19 PM   #4
harma24
My guess is that it's parallax. With a needle sitting in front of the dial face, the viewing position can cause the needle to appear in a slightly different position.
If you were shorter, it would not be a problem!
Family Cars: 1993-2014: 1993 Honda Accord 10th Anniversary Edition | 2014-Present: 2014 Honda Odyssey
Stable-mate: 2019 - present: 2020 230xi Seaside Blue Convertible
      08-23-2019, 07:48 PM   #5
madmax240
Drives:
You must be in reverse.
      08-23-2019, 08:14 PM   #6
BlueGreen86
Drives: None
It’s parallax. It is common in aviation steam gauges. Nothing is wrong with your car.
      08-23-2019, 08:15 PM   #7
Lucky13
Lucky13
Drives: 2014 M235 manual, 2020 X3 30X
I just went to the garage and checked mine and it is at the line not below.
1995 325i, 1996 328ci, 1997 528i, 1997 Z3 2.8, 2000 528i, 2001 X5 3.0, 2001 330i Convertible, 2002 M3 Convertible, 2003 M3 Coupe, 2004 M3 Coupe, 2004 Z4 3.0, 2004 X3 3.0, 2007 X3 3.0, 2007 335i Convertible, 2013 X1 28 sdrive, 2014 M235 manual, 2020 X3 30i Xdrive
      08-24-2019, 04:30 AM   #8
morphomeman
morphomeman's Avatar
593
Drives: 2015 M235ix
2016 BMW X3  [0.00]
2015 BMW M235ix  [0.00]
The more important issue is accuracy while under way.
Check the speedo against the readout on a phone app. Even simple ones like Waze have digital MPH readouts.
Remember, though, that BMW speedometers are notorious for overestimating speed, by a good few MPH once you are up there. So if your speedo needle sits at 75, your phone readout is likely to be 73, even for an 'accurate' reading speedometer.
Tslbmw73.50
      08-24-2019, 09:25 AM   #9
Maynard
Drives: 228iX & M2C
More important is whether the needle matches the electronics - if you set cruise at 60 or 120 by the numbers, does the pointer line up exactly?
      08-24-2019, 08:12 PM   #10
harma24
100% True. Helps minimize speeding tickets though! It's nice knowing that if I am cruising at 10mph above the speed limit, I'm actually only ~8mph above the speed limit and much less likely to be pulled over!
With a (near) vertical needle, the effects of parallax are negated as you are looking at the needle straight on (assuming you're not one of those a-holes that drives slumped over to one side). Parallax would only be an issue when the needle is near horizontal and you are looking down on it (like it is at 0kph or 260kph).
      09-02-2019, 12:26 AM   #11
aerobod
aerobod's Avatar
3626
Same speedo from off centre and on centre, showing parallax error when not viewed straight on:
harma24402.50
      09-03-2019, 05:25 AM   #12
doccyber
doccyber's Avatar
Drives: %D0%97%D0%B0%D1%81%D1%82%D0%B0
Well. Mine sits a little bit above. Even when viewed straight on. Waze does say that I'm off by 2 mph. For example 65 on speedo is 63/62 on Waze. I've lived with it.
      09-03-2019, 08:23 AM   #13
morphomeman
593
Drives: 2015 M235ix
2016 BMW X3  [0.00]
2 mph over at 65 mph is about right for a BMW. I have never owned one with an accurate speedo reading. They are always optimistic. Maybe to massage the owner's ego.
