2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Jb4 maps and help!!!!
      08-18-2019, 01:44 AM   #1
KRAZSMILEZ18
Meat Missile
Drives: Bmw m235i xdrive
Question Jb4 maps and help!!!!
Hey guys, so I need some help. Super new to this and I need to learn more please! I’m not sure if I should be looking at boots and/or what I should be running in my car. I have a 2015 bmw m235i xdrive n55 with a catless DP, an intake, and the jb4 tune. Currently I’m running it on map 6 with the certain boxes filled out, and I need to know what I should change up a bit. Very confused on if I throw these numbers in the boxes and use map 2, if it even will work like that. I am at 30% e85 and the rest 91 octane here in Colorado. I am not running close to that 17 boost and I’m not sure if I should even be looking at ecu_psi or “boost” through everything. Need some major help!😂🤷🏼*♂️
      08-18-2019, 09:47 AM   #2
sdhasher21
sdhasher21's Avatar
Drives: 2016 M4
You should probably move to map 5 for now. Map 6 is for custom tune and not one you want to mess with yourself unless you know what you're doing. Map 5 is adaptive. I'm running a similar setup as you on map 5 and it's been good. I'd check n54tech for more info, since that's the Jb4 guys' forum.
Also, your IAT is pretty high. I'm in Southern CA and the max for me has been 120, but usually around 100-108 on a hot day (85 degrees). I also upgraded my intercooler, though.
Not sure how the high altitude for you comes into play, but I'd switch to map 5 ASAP or map 2.
      08-18-2019, 11:53 AM   #3
KRAZSMILEZ18
Meat Missile
Yeah I changed it to map 2 and it runs about 15.4 boost and it's pretty fast, but do those even matter to write those down when I'm in map 2? Or is that strictly for map 6?
      08-18-2019, 12:02 PM   #4
sdhasher21
sdhasher21's Avatar
Drives: 2016 M4
Easiest way to check is take a look at the settings when in another map. Definitely recommend emailing Terry at BMS or visit the above forum, as it has a lot of good info.
      08-18-2019, 06:37 PM   #5
KRAZSMILEZ18
Meat Missile
Ok cool. And do you know if I can run full e85 on map 5 or even full on map 2? Which one makes more power?
      08-18-2019, 07:14 PM   #6
sdhasher21
sdhasher21's Avatar
Drives: 2016 M4
Usually can't run 100% e85 without some serious fuel upgrades. One thing I will say is to log a lot and learn to read the logs.
      08-18-2019, 07:31 PM   #7
KRAZSMILEZ18
Meat Missile
I put it in map 5 again with that 30% e85 and I'm getting really low boost
      08-18-2019, 07:33 PM   #8
KRAZSMILEZ18
Meat Missile
Barely getting even 12.9 psi
      08-18-2019, 08:07 PM   #9
Pray for Mojo
Drives: 2014 M235i & 2018 X3 M40i
You aren't going to get a ton more boost given you live at altitude. Do the math between where you live and sea level, most guys making 17-18 are at sea level not 5,000 ft.
      08-18-2019, 08:13 PM   #10
KRAZSMILEZ18
Meat Missile
So I should stay on map 2 then most likely.
      08-19-2019, 12:09 PM   #11
Pray for Mojo
Map 2 is probably the upper limit for the stock turbo at altitude, even at 15psi you are beyond the efficiency range of the stock turbo, which means it could wear out quicker. I'm only at 3,200ft and mine struggles to make 15-16psi on a flash tune.
      08-19-2019, 12:10 PM   #12
KRAZSMILEZ18
Meat Missile
I'm making 15.9 psi on map 2
      08-19-2019, 12:12 PM   #13
Pray for Mojo
You can make that boost, but it will make a bunch more heat and potentially wear out the turbo. What altitude are you actually at? Map 2 is absolute so it will force the wastegate closed and make the boost no matter what, it's debatable whether its a good idea though.
      08-19-2019, 12:13 PM   #14
KRAZSMILEZ18
Meat Missile
Interesting. Idk the exact altitude, but it's Arvada, CO
      08-19-2019, 12:17 PM   #15
Pray for Mojo
Wikipedia says 5,300ft. If you look at the real barometric pressure on a weather app and compare it to sea level you are probably down like 20% absolute pressure. At 3,200ft I make 15% less boost with wastegate duty cycle at 100% at 6,200rpm.
      08-19-2019, 12:24 PM   #16
Pray for Mojo
I'd personally run map 5, 80% of 17psi is 13.6psi. The actual math would depend on the real pressure differential. You aren't missing anything since every car in Colorado is down on power compared to sea level.
      08-19-2019, 12:30 PM   #17
KRAZSMILEZ18
Meat Missile
I hate altitude. But thank you for your help. I may have to check more on everything!
      08-19-2019, 12:33 PM   #18
Pray for Mojo
It sucks, I know all too well. The only reason the stock turbos have the available head room is folks at altitude. BMW leaves enough room so the dude in the Andes at 8,000ft is making stock power.
      08-19-2019, 07:26 PM   #19
KRAZSMILEZ18
Meat Missile
Damn
