2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Sport Display gauges
      08-16-2019, 04:09 PM   #1
bustedknuckles
Drives: BMW M235
I just bought this 2014 M235 with 7100 miles on it. I ave a couple questions. I had the sport display gauges on the screen today and did a third gear roll out and the HP gauge was dead nuts between 300 and 400 Hp which I would assume is 350. I had a passenger verify this later on with the same scenario. I know it's rated or under rated at 320 HP, how accurate is this gauge? I don't think it was previously modded because I was told the low miles were because the original owner used the car to drive to Florida every year.
Second, I bought it from a BMW dealer and verified that the brake fluid flush and oil change was performed but when I asked him if the coolant had been flushed and filled the service tech said it wasn't necessary until 100k miles. My previous BMW's had far more frequent intervals. I know it's super low miles but being 5 years old I'm wondering if I should really have it done. Thanks in advance
      08-16-2019, 07:47 PM   #2
rexed
Drives: 05 525i, 18 230i, 18 X3 3.0
After 5 years, you definitely should change the coolant. Probably better off every 2-3 years. You should change both the main radiator as well as the intercooler radiator using a vacuum filler.
      08-16-2019, 08:20 PM   #3
White Glint
Drives: BMW M235i
The sports gauges are based off the position of the throttle, drive mode and gear, they do not actually measure torque/hp
in real time, just an electronic estimate.
      08-17-2019, 10:32 AM   #4
bustedknuckles
Drives: BMW M235
Thanks to you both. I thought five years seemed like way too long of an interval.
      08-17-2019, 07:40 PM   #5
keylime503
Drives: M2C 6MT, Audi A4 Avant
My HP/torque gauges go almost exactly to the 335 HP and 369 TQ the car is advertised as having.
