2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum 2014 2er Reliability?
      08-19-2019, 07:22 AM   #23
happyjack
happyjack's Avatar
Drives: '21 F87 M2C 6MT
Originally Posted by Kolyan2k View Post
35k miles had charge pipe replaced, rear tail lights, and HK amp
WRT the charge pipe, are you running any sort of tune on your car?
my garage: '23 G05 xDrive40i m-sport; '21 F87 M2C, 6MT; '17 F25 x-drive28i SAV; '15 F55 mini hatch 5-door
retired: '87 E30 MT 'vert; '92 E36 sedan; '99 E36 MT 'vert; '06 E90 x-drive sedan; '07 E83 x-drive30 SAV; '09 E91 x-drive wagon; '12 E89 Z4 MT M-sport; '15 F22 sport line
      08-19-2019, 08:00 AM   #24
seansurfn2
Drives: 2014 M235i m-sport
Originally Posted by GregoryG View Post
I'm pretty sure the charge pipe is and I might have tackled the job myself if I had time. The oil leaks were more labor intensive and not something I wanted to mess with. Dealership wanted $2k just for the oil leak repairs, but my local independent shop did all 3 repairs for under $1400. Hooray for the little shops!
learn to do your own work.. those were fairly doable repairs amd youd have 1400 bucks in your pocket.
      08-24-2019, 08:15 AM   #25
steeveebee
Drives: 2018 M2
2014 M235i 6MT
I've had to have the OFHG replaced at ~41K. It was weeping more than leaking, but it had to be done. About $1100 all in.
It's pretty much the problem with the N55. It's dissatisfying to have to put that much into a relatively young car, but it's still a fun car that is satisfying to drive for the most part.
My other car is a 2002 S2000 that I got in 2004, and it has never required unexpected repairs. Generally I think the Honda is a significantly higher quality vehicle.
      08-25-2019, 09:17 PM   #26
JaZoN_XD
Drives: 2008 Honda Accord
Originally Posted by steeveebee View Post
2014 M235i 6MT
Ouch, quite a bit just for a gasket to be replaced. Do you have any issues with the valve cover gaskets yet? Seems to be a recurring theme as well.
      08-30-2019, 02:26 PM   #27
Kolyan2k
Drives: 2006 S2000
I wasn't, it was super hot outside and I floored it, clip that holds the pipe broke
      09-03-2019, 01:19 PM   #28
seansurfn2
ever find out why the amp died? i had one on my 335i die but right after a rear fender bender.. heard moisture but i think sudden violent jolts caused it..
i have a m235i now with 58k miles. right now im using it for work so im puttin on lots of miles til i trade in 6 months for the m240i. ill likely surpass many of you in miles so ill try to document maintenance as it comes up
      09-03-2019, 02:26 PM   #29
happyjack
happyjack's Avatar
i'm at 72K miles...no issues other than run-flats and light bulb replacements being replaced A LOT.
      09-03-2019, 04:41 PM   #30
zentanker
zentanker's Avatar
205
Drives: 2016 M Sport 228i Mineral Grey
The only problem I had with my '15 is the BT stopped working... BMW did a quick update to newer software and no problems since.
I'm at 56000 miles
      09-03-2019, 06:31 PM   #31
morphomeman
morphomeman's Avatar
593
Drives: 2015 M235ix
2016 BMW X3  [0.00]
2015 BMW M235ix  [0.00]
Now if we only knew what BT was . . . bat trap? bilge tote?
      09-03-2019, 06:32 PM   #32
morphomeman
593
Drives: 2015 M235ix
2016 BMW X3  [0.00]
Oh wait a sec, Bluetooth!!!
      09-04-2019, 01:13 PM   #33
Kolyan2k
Drives: 2006 S2000
It didn't die. It's a common issue in 2s. It would just stop working 1-2 times per month, then you restart the car and it would work again
      09-10-2019, 11:54 AM   #34
seansurfn2
weird
well at 59k miles i just had to replace the oil filter housing gasket..
pretty typical for these cars. so far thats it *knock on wood*
still better than the n54 i had last where everything broke..
my electronic steering rack had oil all over it too..thank god that works cause its 4grand
the oil filter gasket dyiin at 58k miles is kinda lame though bmw
honestly makes a few things shitty. i know on the jointly designed b58
i wonder why no gaskets are used and gasket sealer instead.. prob because
with toyota involved a bit they pushed for it knowing bmw is
making crap that fails almost like clockwork after warranties expire..
i woulda done it myself but the cars on the rack already with the new race intercooler and charge pipes goin on now.
      09-10-2019, 12:02 PM   #35
seansurfn2
Last year I bought a 2014 M235i 6MT and until now it's been problem free. This week I discovered oil leaks on the valve cover gasket and oil filter housing gasket, and my charge pipe blew. All of this at 45k miles. Now I've seen that people on here say these are common issues with these cars, but I think it's crap that these items fail so soon.
This is my first German car and I'm ok with the expensive routine maintenance, but to this point the required fixes have been quite unsatisfying.
58k miles oil filter gasket here too just today
im lookin for another beater daily to drive for work and
the heavy driving now is temporary. everything else is fine though.
      09-21-2019, 08:29 PM   #36
Nitrof23MT
Drives: 228ix convert, 528i, x3 35i
My 2015 228i convertible xdrive has been fairly problem free at 66k miles. Couple things I've seen with it though: my choice in tires (not the cars fault lol). Blew 3 this year I'd opt for non run flats...potholes are killer for run flats. Something is up with my AC. On long trips like 5 hours my blower fails...you can feel the cold air but doesn't blow much out at max speed. Never have a problem in town so procrastinating to fix it. This happened on my 1996 528i a couple times (car still running at 300k miles.) so kinda used to it 🤷🏼*♀️.
      09-25-2019, 12:31 AM   #37
seansurfn2
the boards on the blower motor electronics are poorly made ..
i had to replace it on my 2008 n54 335i.. it was recalled but i remember the connector soldering area was burned. it almost burn my car.. then compared the new "revised" valeo part to the old. nice secret fix bmw made or valeo should i say.. shame on them.. thats why i keep the ac cold 60 degrees but never crank it up thus stressing the motor or creating heat..
      09-29-2019, 10:09 PM   #38
Hites
Drives: BMW 228i xDrive
Said it before I could.
I need to open my own shop, because I could buy all the necessary tools 10x over at those prices.
      10-04-2019, 07:21 PM   #39
Luftwaffe1O1
Drives: M235i, 2000 Z3
Mine has been mostly ok, 2014 at 53k miles.
3 months after buying it, the nav was resetting occasionally and they replaced the entire nav computer etc.
Other than that, oil filter housing was leaking, and the alternator belt snapped. But these were all warranty fixes. The only other thing that actually went bad was the valve on the exhaust was rattling, but using M2 exhaust now, and it has been welded open.
      10-05-2019, 08:35 PM   #40
seansurfn2
its all good.. its definitely a challenge with these cars but i notice workin on my lexus is cake compared to my n54 i used to have. Makes all other other cars seem so simple.
      10-12-2019, 06:50 PM   #41
IndyRed128i
IndyRed128i's Avatar
223
Drives: 2022 BMW 230I(Red)
I have a 2016 228XI with M-Sport and the only issues I've had so far are lightbulb burnouts.
28K miles on it.
