Hankook R-S4 235/40/18. Anyone drive on this size tire w/ MSport |
07-21-2019, 10:03 PM | #1 |
Rep 310
Running on 18x8" et42 228i M-Sport with THP Anyone running a square set-up in this size? I have run 245/35;18s without any issues but the 40 series is slightly taller. I checked Will They Fit and the inside clearance is fine. |
07-22-2019, 12:47 PM | #2 |
Rep 260
I run Falken RT615K+ in 235/40/18 on 18x8 et40 square. I believe the tread width between the two tires should be very similar. I also have M-Sport with THP. No problems with this tire setup.
10-10-2019, 01:43 PM | #3 |
Rep 294
Drives: 2019 M240i Coupe RWD
10-12-2019, 08:58 AM | #6 | |
DisplacementReplacement
409
Rep 1,101
Do the 235's rub in front on the et45? I want to run 235/40 and 265/35 but have read et45 on front rubs, would need at least 3mm spacer and i'm not in love with spacers. look forward to hearing, thanks.
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
10-12-2019, 09:24 AM | #7 | ||
Rep 197
10-12-2019, 03:04 PM | #8 |
409
Rep 1,101
Ok cool (wow that is close), r u running the 265 rear also on a 50et?
