2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Car Not pulling as hard/ Rough Start
      06-17-2019, 02:08 PM   #1
wahooooman
wahooooman's Avatar
Drives: 2010 Atlantis M3
Hey guys,
Feel like my car has not been running right for a while now. Was wondering if anyone can take a look at my logs and see if anything seems out of place ?
Looking for a general direction on where to start! thanks
https://datazap.me/u/wahooooman/log-...17-25-27-30-31
https://datazap.me/u/wahooooman/log-2?log=0&data=1-4
Mods: FBO, Enzo BEF, Jb4
Fuel: 93
07 e90 335xi- Sold, 09 X5- Sold, 12 e92 335 xdrive - Sold 11 e92 M3- Sold, 15 M235-Sold,07 e90 335xi (current daily), 10 Atlantis e92 M3 (current) Way to many mods to list
      06-17-2019, 02:53 PM   #2
jondagger
Drives: 2016 M235i
What is your mileage? when was your last sparkplug swap? Gapped?
Also, what confuses me is how your IATs get colder throughout the entire pull....
      06-17-2019, 02:57 PM   #3
wahooooman
wahooooman's Avatar
Mileage is 55k, Spark plugs done last week Gapped at 0.020, yeah that is strange i did not even notice that
      06-17-2019, 03:00 PM   #4
jondagger
Drives: 2016 M235i
Good stuff...
Yeah looks like there is a leak man, those temperatures are standing out to me. check chargepipes and intercooler connections?
      06-17-2019, 03:02 PM   #5
wahooooman
wahooooman's Avatar
Good stuff...
Hmm, Ill take a look to make sure i dont have a leak, thank you
      06-19-2019, 11:14 AM   #6
jondagger
Drives: 2016 M235i
update?
      06-24-2019, 01:32 PM   #7
wahooooman
wahooooman's Avatar
update?
So No leaks, Burger says the logs look good and IATS are proof my intercooler works.
But what I find strange is on Map 0 i boost between 17-19 pounds and on map 5 and 2 its 15-17 psi. And map 3 with meth is lower.
I do have a BEF but I would think if map 0 is 17-19 psi so would the other maps.
      06-25-2019, 12:29 AM   #8
M235SDCA
M235SDCA's Avatar
Drives: 16 M235 Vert
Are you just using the JB4 as a meth controller? When I was running a JB4 with BEF map 6 worked the best, and I used it for meth also. Map 3 was worse. With that BEF I don't expect the JB4 will give you additional boost.
18 340i F30 mostly stock
      07-14-2019, 09:17 PM   #9
MegaMatt3
Bimmer Candidate
Drives: '16 M235i
What do you use for logging?
      07-16-2019, 09:10 AM   #10
wahooooman
wahooooman's Avatar
Good insight, thanks! I guess i would be just using it for a meth controller, i thought once you enabled the BEF on the jb4 it would have less affect as the BEF is providing the "tuning". I also had a issue with a pretty large misfire and cloud of smoke after changing off of the meth map which happens pretty often lol. So you suggest using map 6 for a meth map ?
QUOTE=MegaMatt3;25027230]What do you use for logging?[/QUOTE]
I am using the Jb4 to Log, but I suspect it is what is causing my issues may go Flash only.
      07-16-2019, 11:41 AM   #11
M235SDCA
M235SDCA's Avatar
With the BEF that you have I just don't see the JB4 adding much if anything at all. One issue that I had is that the JB4 can't simulate the full range of the MAP sensors. Your one file shows DME targets of up to 17.9. The JB4 IIRC could only simulate around 20 so if your target is close to this the control loop may not function correctly. Even so with this target you're not going get much more with the JB4 - maybe another 1 PSI or so.
So this misfiring that you had was while running meth? I had an issue like this, primarily at higher RPMs when there was some kind of traction control event. In this case, the throttle would close but the meth stayed on. Mixture went really rich like into single digits and all kinds of misfiring until I let off the pedal.
