2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack my experience mounting 265/30/19 rear tires ,guide for someone who want to mount thi
      06-07-2019, 07:26 PM   #1
gerry25
gerry25's Avatar
31
Drives: bmw m240i
hi
yesterday i replaced my wheels in my bmw 240i rwd lowered with h&r 20mm springs.
i was running 19x8.5 et 38 front toyo 225 35 19
19x9.5et 45 back toyo 255 30 19
This combo doesn't rub anywhere, but rear tires looked very stretched, there wasn't protection for the lip of the wheel so i thinked that will be a good idea to put 265 tires in the rear.
i wanted to change wheels so i bought a set of apex ec 7 wheels 19x8.5 et 35 front put 225 35 19 and don't have rubbing but my rear 19x9.5et 43 with pirelli p zero rub a lot, everywhere !
Today i rolled the rear fenders and they still rubb but a lot less.
i readed that michelin run wider than other brands ,with my experience i think pirelli too
do you know which brand tires are stretched? i still want to run 265 tire in the rear
thanks
Last edited by gerry25; 06-19-2019 at 11:43 PM.. Reason: i end testing and solve my problem so here is a guide
      06-07-2019, 08:07 PM   #2
Joe240
Joe240's Avatar
Drives: 2021 C8 Corvette 1LT
Only way to avoid rubbing on 265s is high offset wheels. Need 9.5et47-52 to avoid rubbing in the back when lowered. Might also need a tad of camber but the lowering springs should provide enough. Otherwise, et45 or less has poke and you’d need to be on factory suspension to avoid rubbing.
      06-12-2019, 09:59 PM   #3
gerry25
gerry25's Avatar
31
Drives: bmw m240i
thanks for the response joe
as i mentioned i had no problem with 255 tires in the back but i decided to change to 265 in this new set
i readed you test your car with 19 wheels and 265 tires in the back, did you have the same problems?
NOT2DAY117.00
      06-12-2019, 11:24 PM   #4
Joe240
Joe240's Avatar
I ran 19x9.5et44 and second set was 18x9.5et45. Both with 265s. I was on stock suspension so had no rubbing. I definitely had poke that lowering springs would’ve caused rubbing.
      06-14-2019, 11:28 AM   #5
NOT2DAY
Drives: '15 M235i 6MT
The ET43 in the rear is killing you, you need ET47-52 range. I run ET48 (ET58 + 10mm spacer) and my 265 MPS4s clear the back without a problem - I'm also lowered on Dinan Springs.
      06-16-2019, 11:36 AM   #6
gerry25
gerry25's Avatar
31
Drives: bmw m240i
i think tomorrow i will mill the pancake of the wheel to increase the et and try with other brand tire that run narrow.
do you have clearance between the tire and strut?
thanks
      06-16-2019, 12:39 PM   #7
Maynard
Drives: 228iX & M2C
Milling wheels seems terribly risky, even if you have access to the kind of accurate mills that you need for this. Just b/c you can get it to fit does not mean it will hold together at speed.
      06-16-2019, 02:31 PM   #8
B58togo
Drives: M240i
Need more offset. I'm running 9.5 et58 with a 5mm spacer and I installed 265 Michelin PS4S a few weeks ago. They're pretty close to flush and look great.
      06-17-2019, 03:52 PM   #9
jondagger
Drives: 2016 M235i
did you run 5mm up front? what is your front tire? is the wheel supported by the hub well?
thanks mate.
      06-17-2019, 04:47 PM   #10
gerry25
gerry25's Avatar
31
Drives: bmw m240i
today i installed a sumitomo 265 30 19 in the rear
im not joking when i compare the existent pirelli p zero vs de sumitomo with the same size ,it looks like the pirelli is wider by a lot,
the section width of the pirelli is 10.8 and the sumi 10.5in
i ran the sumi in the pilot side and the p zero in the passenger side, i did 25km today and don't have rubbing problems with the suminoto obviously the pirelli still rubbing.
i don't call victory until i install both wheels with suminoto but i think it will work.
      06-19-2019, 11:37 PM   #11
gerry25
gerry25's Avatar
31
Drives: bmw m240i
today i finally installed the passenger side rear tire, brand suminoto,so now both rear tires are suminotos.
i can say i don't rub anymore
if someone want to install 265 30 19 tires in back take note
find a narrow tire like the suminoto i think hankook is narrow too.
i rolled my rear fenders because of the wider pirellis i had first but they kept rubbing so i advice don't use michelin or pirellis or other wider brand tires, probably rolling fender won't be necessary with narrow tires.
i puted springs spacers, they are square pieces of rubber that limit the spring movement,i dont want to try without them but probably aren't needed.
my rear wheels are 19x9.5 et 43 so people with et 45 will easily can fit 265 rear tires.
i really tested it, i live in mexico and believe me we have a lot of imperfections in the street that put in test that my car dont rub.
im on h&r springs that are supossed to drop the car 20mm, i think in real life they droped my car like 25mm in all corners, so people with moderate drop like me won't have problems.
hope this post help people like me that dont find a lot of info to mount 265 tires in rear.
this post is 100% tested and real ,unfortunately it cost me 2 pirelli p zero that dont fit, time testing and money mounting tires
      06-20-2019, 12:55 PM   #12
B58togo
Drives: M240i
thanks mate.
18 x 8.5 et 45 with a 5mm spacer and 225 PSS. Gotta go 235, because 4 size variance has created understeer and has zapped some fun. The extra straight line grip is a decent consolation prize. I so wish we could run 255/275!
      06-23-2019, 10:46 PM   #13
gerry25
gerry25's Avatar
31
Drives: bmw m240i
final shots!
https://ibb.co/DbdnQv5
https://ibb.co/6cS8qdS
https://ibb.co/HFNBTmc
https://ibb.co/6Xgd0f5
Hekler29.00
      06-24-2019, 10:36 AM   #14
Kefka
Drives: 325i, 135i, 335i e93/92 , Z4 3
What is the size of those pzeros?
265/30/19?
And yes pZeros are wider than a regular tire..
      06-24-2019, 06:37 PM   #15
gerry25
gerry25's Avatar
31
Drives: bmw m240i
265/30/19?
yes 265/30/19
      08-08-2019, 01:16 PM   #16
ktrvn
ktrvn's Avatar
No_Country
102
Drives: 2012 E92 M3 Comp
Got any photos of your setup? are you lowered?
      08-11-2019, 05:12 PM   #17
Hekler
Drives: 2019 M240i Black on Black
Nice looking setup. What is the rim? Also what size and offset you using?
      10-01-2019, 10:31 AM   #18
MassNerd
MassNerd's Avatar
Drives: 2019 M240i Coupe RWD
bumping this thread as I'm rim shopping for next spring (maybe those new Apex forged...)
Interesting point B58togo. Have you gone to 235 in the front yet? I was considering 265s in the rear, but don't want to completely ruin the balance of the car...
      10-01-2019, 11:46 PM   #19
235Dude
Drives: 2016 M235i
Very helpful! I just ordered 19" apex wheels in the same sizes 19x8.5et35 and 19x9.5et43. I really wanted to run 235 and 265 but played it safe with falken fk510 in 225/35/19 and 255/30/19. I'm lowered on 10mm M Performance springs and will post pics when I get them (currently back ordered)!
      04-25-2020, 07:57 PM   #20
gerry25
gerry25's Avatar
31
Drives: bmw m240i
congrats! this wheels look insane, with your tire sizes you don't have problems , how is your ride with the m performance springs? do you have adaptive suspension too?
      04-25-2020, 07:59 PM   #21
gerry25
gerry25's Avatar
31
Drives: bmw m240i
sorry for the late my wheels are19x8.5 et 35 front with 225 35 19
rears 19x9.5et 43
