2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Reverse mirror tilt stopped working
      02-10-2018, 07:08 PM   #1
OrangePeanut
Drives: M235i BSM
2015 M235i  [0.00]
Mirror tilt stopped working randomly for me. I verified the code is set properly, and I haven't coded anything new in almost half a year. The passenger side mirror just won't tilt anymore when I go in reverse. 2015 model, manual transmission. Anyone else experience this?
      02-10-2018, 07:42 PM   #2
bmw_f22
bmw_f22's Avatar
United Kingdom
17
Drives: BMW F22 220d M-performance
Have you plugged your car in and seen if it's thrown up any error codes ?
I have access to BMW workshop service software that diagnoses and identifies all fault codes and can retrieve all installation/removal instructions provided by BMW for the mechanics and detailed info about wiring etc you get my point lol
      02-10-2018, 08:09 PM   #3
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
You probably moved the mirror selector to the right.... it has to be to the left to the tilt to work
      02-10-2018, 09:10 PM   #4
OrangePeanut
Drives: M235i BSM
2015 M235i  [0.00]
damn, kinda figured it was something stupid. Totally forgot about that little switch over there. It's working now lol, Thanks!
      02-10-2018, 10:03 PM   #5
pikcachu
pikcachu's Avatar
1399
      02-14-2018, 01:05 PM   #6
stlb5
stlb5's Avatar
217
Drives: '19 M2C MT, '15 X5 Msport
I did the same thing about a month ago
      02-21-2018, 11:49 AM   #7
Maynard
Drives: 228iX & M2C
I'm still learning to love a car that is smarter than I am too...For me it was accidentally putting it into stop/start mode and freaking at the first startup, thinking the guy behind had tapped me. Good thing they also make us taller and more attractive
      02-22-2018, 08:40 AM   #8
barfastic
Greece
37
Drives: 228i M Sport Pack
can you activate mirror tilt on reverse (via coding) if you dont have comfort access?
      02-24-2018, 07:34 AM   #9
that2msportguy
Drives: 2015 228i Msport
^ same question
      02-24-2018, 09:29 AM   #10
cxp213
cxp213's Avatar
313
Pretty sure I saw an option for this while coding but I figured I'd ask here while the topic's come up:
Can I change the angle of how much the passenger mirror points down while reversing? It's a bit too much angle for me and would like it to point down less.
      02-24-2018, 10:15 PM   #11
pikcachu
pikcachu's Avatar
1399
FEM_BODY 3110 ASP_BORDSTEINAUTOMATIK_DELTA
cxp213313.00
      03-02-2018, 04:40 AM   #12
serko ex
Drives: 2018 BMW M240i
I find the mirror tilt useless and would rather have the mirror not tilted so i can avoid hitting an object rather focusing on parking lines.
      03-05-2018, 09:35 PM   #13
that2msportguy
My mirrors don’t fold on reverse neither I have to do it manually every time as I park in reverse to not drag or hit my front bumber
      06-11-2019, 08:29 PM   #14
Gweeper64
Gweeper64's Avatar
Drives: '13 128i N51 6mt M-Sport
Thank you! This just started on me the other day... after I adjusted my right mirror... now it makes sense.
      06-18-2019, 01:38 PM   #15
Cjnj
Drives: 2016 228i xdrive
The tilt on reserve has nothing to do with comfort access. I'm pretty sure it is standard on all cars with the premium enhanced (or at least in Canada). Basically if it doesn't work when your mirror selector is in the correct position than your car probably doesn't have it.
      06-18-2019, 01:53 PM   #16
aerobod
aerobod's Avatar
3624
In Canada you don't need any specific package for mirror tilt in reverse, just power seats (which were standard on our 2017 M240i). Our car only has metallic paint and the storage netting options, nothing else, but mirror tilt in reverse works fine.
