2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions M2 exhaust Gurgle on an m235i!!!!!!!!!!! WOOOOOO!!
      01-22-2017, 12:41 AM   #1
Anderw
Anderw's Avatar
Drives: F80 m3
Sorry for the click bait tittle HAHAH
I am curious if anyone who codes has seen anything for this in the Entries. I know it is possible to remove the m235s exhaust popping as it is A computer added over run, then is the same possible to change it to m2 over run?
The engine is the same for the most part and the exhaust has nothing to do with the rev limiter / over run. Just like people are adding GTS Burble tunes to m3/m4
Is it possible to give A m235i the same snapping sound the m2 makes when coming off the throttle at high RPM or shifting hard high in the rev range?
I am going to talk to the guy who coded for me before and I will try to get this to work But in the mean time has anything ever through of this? or am I the only one
Video reference , not so noticeable here but you can see what I mean its much louder and noticeable when driving
      01-22-2017, 09:22 AM   #2
Gabrola
Gabrola's Avatar
191
Drives: 340i
It can be done but through a flash tune not coding.
Anderw658.50
      01-22-2017, 09:30 AM   #3
RoundelM3
RoundelM3's Avatar
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
^ This! Engine parameters aren't part of feature or vehicle option coding. Just like the MPPK flash tune creates more burble over the stock tune, it requires changes to the engine control parameters/maps, which are vastly more complex than turning a feature on or off. Not sure if even a piggyback tune could do this.
Anderw658.50
      02-07-2017, 06:24 PM   #4
abomb60
Drives: 2016 M235i xDrive
The M2 exhaust is much freer flowing than the stock M235. The m performance exhaust or another aftermarket may be what you want on the M235i. Here's a video with what mine sounds like driving around ...
      02-07-2017, 07:19 PM   #5
Anderw
Anderw's Avatar
Drives: F80 m3
I have 4 inch catless downpipe already so it's not tone or volume I'm looking for , it's the sound an M2/3/4 makes when it bounces off the rev limiter or comes off hard throttle.
Its In the programming where the difference between the cars lies since the M2 and M235i are working with pretty much all the same hardware but make different sounds , I am more familiar with coding so I was hoping that would be the answer, but it more likely to be something that would need to be flashed
      02-08-2017, 07:46 AM   #6
abomb60
Wouldn't it be possible to reflash the DME with M2 software using winkfp? I know we used to do this a few years back to put Alpina DME software into the 335's and euro SMG software into the M5.
      02-08-2017, 01:55 PM   #7
Gabrola
Gabrola's Avatar
191
Drives: 340i
Lol noooo... It's a totally different engine, well not totally but it's a different engine block, pistons, turbocharger, intake, etc.
Also if it were the same it's not possible to reflash a DME without physically unlocking it since the DME will be locked and you won't be able to re-code it with a different power variant. F-Series cars don't use WinKFP either.
      02-08-2017, 02:56 PM   #8
jpnh
jpnh's Avatar
1424
Drives: NA
I'm waiting for the Dinan exhaust with mid pipe for the B58 in the M240
Here it is in the 340...fast forward a bit....
      02-13-2017, 07:21 PM   #9
bryan_G01
bryan_G01's Avatar
1165
Drives: like i stole it...
Catless DP with fabspeed muffler delete.
www.nybmwcca.org
Current Cars:
      02-13-2017, 08:45 PM   #10
Anderw
Anderw's Avatar
Drives: F80 m3
Lolol this turned into an exhaust mod thread
      02-19-2017, 04:01 PM   #11
mdputnam
mdputnam's Avatar
289
With the tuning files from proTUNINGfreak's Bootmod3 you have exhaust valve and overrun (burble) control. Upon request proTUNINGfreaks will add in no over run, varying over run depending on comfort sport or sport+ setting (like stock only louder and longer) or obnoxiously insane amounts of over run. Of course changing the exhaust system will make it even harsher, louder, and more obnoxious!
      02-19-2017, 04:03 PM   #12
mdputnam
mdputnam's Avatar
289
With custom tuning files from proTUNINGfreak's Bootmod3 you have exhaust valve and overrun (burble) control. Upon request proTUNINGfreaks will add in no over run, varying over run depending on comfort sport or sport+ setting (like stock only louder and longer) or obnoxiously insane amounts of over run. Of course changing the exhaust system will make it even harsher, louder, and more obnoxious!
      02-23-2017, 10:49 AM   #13
mdputnam
mdputnam's Avatar
289
If you haven't seen it here is the post and video for the Bootmod 3 system.
      02-23-2017, 01:59 PM   #14
Anderw
Anderw's Avatar
Drives: F80 m3
Do you have bootmod3 on your car?
      02-23-2017, 05:49 PM   #15
DJJG-KWSW
DJJG-KWSW's Avatar
Drives: 2007 335i
Are you selling these boot mods?
      02-23-2017, 05:58 PM   #16
Anderw
Anderw's Avatar
Drives: F80 m3
lol it seems that way
BONE SAW!
      02-24-2017, 09:44 AM   #17
mdputnam
mdputnam's Avatar
289
No, but I get a 10% kick back on everyone that is sold!! With that extra income I've been able to pay off my vacaton home in Anguilla
      07-27-2019, 08:09 PM   #18
RocketF22
Drives: 2015 BMW M235i - 6SPD
so what exactly have you done. this is the sound I want but I couldnt get it with my mpe
Justin - Showcase Auto (Owner)
      07-29-2019, 08:15 AM   #19
abomb60
So this car had the MPE, Dinan carbon fiber intake (with the MPPK lower airbox ... this is why you can hear the turbo) and Dinan stage 2 tune so that might have accounted for a bit of the noise.
