2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning M235i Muffler Delete - Initial Thoughts
      07-02-2016, 10:17 PM   #23
Kolyan2k
Drives: 2006 S2000
Wondering is anyone just gutted stock muffler? To keep stock look and valve
      07-03-2016, 12:54 AM   #24
BentZero
BentZero's Avatar
Check out this post by Mywifes335. I finally found a shop that can do the work. I may give this a shot depending on what they want to charge me. I'll skip the bypass tube, but definitely want to remove the resonator and gut the back box.
http://www.2addicts.com/forums/showt...php?p=19515910
Build thread
      07-03-2016, 02:02 AM   #25
Kolyan2k
Drives: 2006 S2000
Em... thanks. So I guess I would want to remove all fiberglass from back muffler and probably replace inside with straight tubes
      07-03-2016, 02:02 AM   #26
BentZero
BentZero's Avatar
Em... thanks. So I guess I would want to either remove all fiberglass from back muffler and/or replace inside with straight tubes
both
Build thread
      07-03-2016, 02:04 AM   #27
Kolyan2k
Drives: 2006 S2000
both
Yeah I meant both. Edited
Now need to find muffler shop that will do it nice.
      07-03-2016, 02:19 AM   #28
BentZero
BentZero's Avatar
Yeah, so what I gathered from it is this:
Delete resonator
Remove packing from 1st and 3rd chamber
Replace perforated tubing in 3rd chamber (and maybe 1st too???) with straight tubing
Build thread
      07-03-2016, 02:48 AM   #29
Kolyan2k
Drives: 2006 S2000
Delete resonator
Well I don't want to remove resonator, just mod the stock muffler box. I assume the stock muffler has 3 chambers? Need to remove all fiberglass and replace tubing in 3rd
Point is not to spend $750 plus install for MPE. It's the same modified muffler. I have never done exhaust on any of my cars, this one is just way too silent
      07-03-2016, 03:57 AM   #30
Kolyan2k
Drives: 2006 S2000
Delete resonator
I suppose this is our muffler. So need to either weld all holes in 1 and 3 or install straight pipes (check original thread as well). This is supposed to be better then MPE by the way.
http://f30.bimmerpost.com/forums/sho...d.php?t=850113
      07-03-2016, 05:48 AM   #31
DanielGr
Australia
24
Drives: '05 LMB 130i
Has anyone tried just the centre resonator delete while retaining the stock/MPE mufflers?
      07-04-2016, 04:07 PM   #32
Beef Supreme
Drives: Future F22?
Sounds good! But will this hurt performance? I've heard that it could actually reduce low end torque a bit. Not sure how true that is.
      07-04-2016, 06:12 PM   #33
Amack
Australia
101
Drives: EB 2016 M235i
I havent noticed any performance issues. Echo mode is a dog down low but its echo mode.
      07-04-2016, 06:23 PM   #34
M235guy
M235guy's Avatar
Drives: 2014 M235i
Delete resonator
I did this to my spare muffler. It was a pita
      07-04-2016, 08:11 PM   #35
Kolyan2k
Drives: 2006 S2000
I wanna go to muffler shop tomorrow and ask them. If they can't do it, that's fine.....will be looking for used MPE. I can't justify $750 bucks for a muffler
      07-04-2016, 09:00 PM   #36
EuroDude
Drives: 2017 GT350
2017 Ford GT350  [0.00]
some pics during the modification would be helpful.
      07-04-2016, 09:22 PM   #37
BentZero
BentZero's Avatar
I'm gonna call a shop tomorrow. I need a stop gap until I save up enough for an AWE or Fabspeed setup. If I'm lucky I'll like this just fine and the money can go towards a sport cat.
      07-05-2016, 10:51 AM   #38
Kolyan2k
Drives: 2006 S2000
Asked the shop to make those 2 pipes solid. Was quoted $400 bucks and guy said he doesn't understand the logic behind leaving the 2nd chamber since everything is going to escape through tail pipes anyway. He said eliminating muffler completely is $200......
      07-05-2016, 11:08 AM   #39
BentZero
BentZero's Avatar
Yeah, I called a shop and they said they wouldn't even do it because the metal on the muffler is too thin to weld. :/ Oh well, guess I'll just continue to save up for an exhaust.
      07-05-2016, 11:44 AM   #40
Kolyan2k
Drives: 2006 S2000
So pretty much this thing is $200 at muffler shop
http://www.fabspeed.com/bmw-m235i-f2...xhaust-system/
      07-05-2016, 06:02 PM   #41
Drpoomanchu
Drpoomanchu's Avatar
Drives: AW M235i Man FBO
Originally Posted by omega145
No...you aren't going to get flames out the back. I don't get why people want to do that. Have to introduce source of ignition in order to get flames like a flame kit or some nonsense like that.
My 2015 WRX catless dp on e-85 shot out flames on some shifts. Ill post a pic, this is what hes asking about, not those kits they sell...
Not my car, this pic is from my tuners fb. I have seen multiple cars do this, on dynos and the street. My car did the exact same thing on the dyno.
Just another good reason to pass on the subi's... First ringlands and now a fire hazard... What next .. !
      07-06-2016, 02:05 PM   #42
Alfonso235i
I did shoot a rod out the side of that Subi and got a 235. Lol
      07-15-2016, 01:30 PM   #43
Mywifes335
Mywifes335's Avatar
Drives: 2014 FBO M235i
Originally Posted by Mywifes335 View Post
You can probably tune it to pull ignition and dump fuel on lift - basically exaggerate the current overrun programming.
Flames are when unburnt fuel is dumped and then ignited by the hot exhaust.
Then you'll need a completely straight through exhaust.
I had fire in my Evo X.
I stand corrected. With race gas and big turbo, it made fire:
That's right, y'all! Yes! 500whp now.
Originally Posted by Axius View Post
Why the sad face, I fucking love sausage.
      07-15-2016, 01:37 PM   #44
BentZero
BentZero's Avatar
I heard a 335 last night with a muffler delete and catless DP. It sounded amazing. Nowhere near as loud as I thought it would sound. Owner said that inside of the cabin is drone city though and is looking to gut his stock muffler and re-attach it.
Build thread
