07-07-2017, 08:46 PM | #199 |
Rep 101
Drives: 2016 m235 xdrive
07-08-2017, 02:13 PM | #200 |
Rep 114
I did find the missing 2 M logo stickers. One was under the flap in the box and the other was actually in one of my pictures stuck to the inside of the wheel...
Took one more close up of the center ring. My stock wheels have a chrome ring around the BMW logo. These have that light gray disc showing where the chrome ring would be. Very small and subtle and you would have to really look closely to see it. The other pic is the label on the box. The offset indicates et 40 whereas Anthony said these were milled to et 39. Dunno how to actually tell what it is. The wheels are tires are at the tire shop. Will be picking them up on Monday and I'll post pics of them mounted.
_________________
2024 M240xi Mineral White, HK, Premium Pkg, Xpel PPF, Xpel Plus 55% tint Sold - 2017 M240xi Mineral White, HK, OEMConcept 437M wheels, Curtis hitch for bike rack, MPE, Painted rear diffuser, Dinan Elite Stage 1 |
FSociety3812.50 |
07-08-2017, 10:46 PM | #201 |
Rep 101
I saw that M sticker on your wheel in the photo and was going to mention it. Haha. Yea, not liking the gray center caps either. I may paint them black or use the OEM center caps if they fit. I also noticed the box said 40 offset on mine. Maybe Anthony can comment on that.
Did you get you car yet bowhun2r ? |
07-09-2017, 06:55 AM | #202 |
Rep 114
Yes, picked it up on June 30th. It wasn't quite ready (no black grills or M rocker panel decals), but they wanted it sold to get a car moved for the month of June.
Got the car back on July 7th with the grill and decals on it. They gave me a loaner for the day I was without the car. The passenger side decal has a few ripples about 4-5 inches long, but I'll probably be the only one who will notice it. The rocker panel decals were not a build option (at least not for me) so I had to purchase the decals and have them slap them on. However, the dealership no longer performs this task and they send it to a local body shop. I'm told the service guys messed up too many of the decals on other cars. My 435xi rocker panel decals were a build option and were put on while at port though. Should have the wheel/tires on the car hoping late tomorrow. I'll post pics of the stock and 437M wheels.
_________________
07-10-2017, 02:13 PM | #203 |
251
Rep 1,636
Can't wait to see pics of the wheels installed on your cars!!!
We used to have different caps however they were seized at customs and we had to pay a big fine. These wheels do accept OEM caps so you can always just snap in your existing caps! |
07-10-2017, 05:56 PM | #204 |
Rep 114
Pics 437M OEMConcept Wheels 18x8.5 et39 or et40..
After about 2 months of ordering the car...placing orders with Anthony OEMconcept and finally getting everything (for now) done...
Here is my M240xi with OEMConcept 437M square setup 18x8.5 et39...but the box indicates et40...so maybe Anthony can say for sure. First.. Anthony is a fantastic vendor. Very responsive and answered my many questions very quickly. I decided to go with BFG Comp-2 A/S in 235/40/18. I also purchased TPMS sensors from TireRack. I can attest they register fine with the M240 and transmit pressure and temperature. Took a reset of TPMS and about 10 minutes of driving. Unfortunately....one of my tires has a slow leak. I checked the pressure prior to installing on the car. While the TPMS was registering my driver rear indicated 30lbs of pressure. Not happy. Will be taking wheel/tire back to installer in the morning. I also think I heard a rub. There is a dip in the road on a hard bend and I think the front right (left turn on the road) might have rubbed. It's a fairly quick corner with a depression. Since my TPMS indicated a leak on the rear driver tire I just went straight home. I'm hoping it wasn't a rub. I checked my fender and didn't see any tire rub (but I also know that sound...). Will verify once I get the tire/wheel leak fixed. I got the McGard lock set on Amazon. The pic below has the model info. Also picked up the spindle on Amazon (also in pic). Makes mounting the tire pretty easy. The before pics And now the after pics Getting ready to install Stock run flats vs the BFG's McGard lock set and spindle via amazon
_________________
07-11-2017, 08:38 AM | #205 |
251
Rep 1,636
Fitment looks perfect! As for the rubbing, I believe BF's run a little wider than your average tire. Your tire is probably running closer to a 245 width. Every tire company is different, some run true to size as others run either narrower or wider.
07-11-2017, 08:44 AM | #206 |
Rep 101
Looks great bowhun2r. Really hope you are not rubbing as my set up is almost exactly the same as yours. I went with Michelin AS 3+ though, but same size. What color is your car, AW or MW? Our cars will be pretty close as mine is MW. My tires got mounted yesterday and I will be picking them up today hopefully. Good to hear that the OEM center caps will fit OEMconcept .
07-11-2017, 08:49 AM | #207 | |
Rep 114
I had the other rear go nearly flat last night. Just came back from the place I got them mounted and ordered 2x 225/40/18 in the BFG Comp 2 A/S. On tire rack my tire does indicate a littler wider than the AS 3+. So...back to the stock tires until Friday (they had to order the 2 tires). The fronts were rubbing on the outer fender lip towards the front. well when hitting a hard bump. At full lock both ways no rub and about an 1/8inch clearance on the strut. The wheels look awesome (at least IMO) the wife even approved of the new wheels/tires even though I have a new car that came with wheels and tires.... Just disappointed in the 2 wheels/tires that have leaks and the front rubbing. But... by Friday that should all be taken care of.
_________________
2024 M240xi Mineral White, HK, Premium Pkg, Xpel PPF, Xpel Plus 55% tint Sold - 2017 M240xi Mineral White, HK, OEMConcept 437M wheels, Curtis hitch for bike rack, MPE, Painted rear diffuser, Dinan Elite Stage 1 Last edited by bowhun2r; 07-11-2017 at 09:02 AM.. Reason: outer not inner fender well... |
07-11-2017, 09:03 AM | #208 |
Rep 101
That sucks. So you had two rears go flat on you? Really worried about rubbing with mine now. The Michelins aren't as wide but a little larger diameter which doesn't help.
07-11-2017, 09:29 AM | #209 | |
Rep 114
I checked the other 3 before going to bed and the two fronts held 35 right on the button. The other rear though was down to 20 psi. This morning I checked the two fronts again and they were right on. Going to reset TPMS now with the stock tires on. It's nice being able to hit the TPMS reset button and not having to pay the dealer to reset the sensors. Makes it easy if you have 2 sets of wheels. You might be good. I will say with these offsets, the wheels are flush to the fender. With my tires being a bit wider than a typical 235...put me over the edge (or I should say into the edge). Now I'll have an extra pair of rear tires.
_________________
tinyTIM33.00 |
07-17-2017, 11:25 AM | #210 |
Rep 101
I got my wheels mounted this weekend. Drove around all weekend and didn't notice any rubbing. Keeping my fingers crossed that I am good. I am running a square setup with Michelin AS 3+ 235/40/18. Wheels are 18x8.5 milled to +39 offset.
07-17-2017, 03:01 PM | #211 | |
251
Rep 1,636
You should not have any rubbing with those specs and tires. |
07-18-2017, 05:42 PM | #212 |
Rep 114
437M wheels take two....
Well lesson learned (expensive lesson). Anyone interested in running BFG's Comp 2 A/S in 235/40/18 with these wheels will experience front fender rub. Likely a fender roll would fix it, but I didn't want to roll my fenders.
tinyTIM Your car looks great. Very similar... I went on tirerack and looked at their column "tread width" for different tires. This is their own custom measurement because tires have different shoulders thus different widths. The Michelins that tinyTIM is running are between the Conti DWS 06 and the BFG's regarding tire width. I went the more conservative route this time and bought 235/40/18 Conti DWS 06 tires and had them remounted on my wheels. The local place called today and said the tires were done. I took my tire pressure gauge with me this time because I wasn't going to head home only to see slow leaks with this setup (as I did with the BFG's). Guess what... two tires (likely the same two with the BFG's) were showing about 20lbs. I told the service tech come take a look... (at this point I was getting pretty frustrated. My wheels from being mounted/remounted/mounted/remounted where showing some wear and tear). It turned out the valve stem had a bad o-ring on two wheels. They put the tires into a water tank and you could see air bubbles by the stem. I told him I bought the set at the same time... I don't want to see my other two wheels go down in a few days. So they replaced all the seals on the valve stems because at this point I think they wanted me gone as much as I wanted to be gone. They were pretty cool about everything. Granted I was paying them to do this, but overall they wanted me to be happy. BTW.. Bruce Brothers Tires in Bethel Park, PA if anyone needs tire work. I spent like 2 hours cleaning up the goo from the weights that were used on the BFG's. Cleaned and then jetseal'd (again). PITA. And no rubbing! Took the exact corner where I hit my fender with the BFG's and no rub. You can see the difference in tire width comparing the BFG and DWS06 in the same size. Actually a pretty decent size variance. Finally mounted. These better handle the PA winter cause I'm about done dealing with wheels/tires for a while. (and I'm not sure why my pics are not showing correct orientation. Deal with that later.) Looking down on the rear wheel OEMconcept Thanks again Anthony. I'm hoping the wheels hold up as well as they look.
_________________
FSociety3812.50 |
07-19-2017, 07:08 AM | #213 |
Rep 101
Looks great bowhun2r . Glad you finally got everything sorted out. I can't believe the difference in width for those two tires. That is pretty extreme.
07-22-2017, 07:50 PM | #214 |
Rep 38
Anthony from OEM Concept
Hi Anthony! When you see this can you please contact me?
I've sent a few PM's to you so I'm assuming those didn't make it to you for some reason as I know you would normally reply! Anyone else on the forum have PM's not go through for some reason? (I do see them all in my sent folder), have been trying to contact Anthony for over a month. Many thanks, Brian |
07-22-2017, 07:52 PM | #215 | |
Rep 114
Anthony has been pretty responsive to my many questions over the entire purchasing cycle. Good luck,
_________________
08-13-2017, 05:36 PM | #216 |
Rep 139
Just got my staggered set up 18 inch rims mounted to my stock tires and on the car. Felt great looks great but my rear tire is already flat. Had to add air. Looks like it's leaking again so back to the tire shop tomorrow to see whas The issue. Any ideas .
08-13-2017, 05:53 PM | #217 | |
Rep 114
Mine have not lost any air since the shop replaced the seals on the sensors. It's now about a month. Look great. Brake pads put down some serious dust. The wheels hide it well, but looking close you can see the build up.
_________________
08-14-2017, 08:58 PM | #218 | |
Rep 424
They said the tpms needs to be replaced and it's like 97$ First how do they know its broken and not a seal, and second why would I pay, they must have broken it during the install.i wonder if BMW covers these sensors with warranty. They removed the entire sensor and now it's just a normal valve so it holds air but the tpms system is off. Sigh. Maybe I need a new thread in case others have the same issue
08-14-2017, 09:09 PM | #219 | ||
Rep 114
I agree...you shouldn't have to pay period. The seals were replaced on mine via the installer and that ultimately fixed mine. I bought the tire rack sensors for my new wheels. They didn't transfer the sensors from my stock wheels. Sounds like the same symptom though.
_________________
08-14-2017, 09:23 PM | #220 | |
Rep 424
