09-04-2019, 12:42 AM | #1 |
Member
Rep 28
m235i brakes worse than expected?
I took my CPO m235i (38k miles) on a canyon run at Angeles Crest highway last weekend.
After going up and coming back down from the canyon, around 20 minutes into the run, there was a noticeable change in the brake feel where I would have to press the brakes almost all the way down to get the car to stop when it was working perfectly right before. I stopped the car for about 10 minutes, then the brakes kind of came back to normal (I also didn't drive aggressively enough to actually test it again). As a previous scion frs owner, I would drive aggressively through the canyon for almost an hour and I would only notice maybe 30% brake fade. The m235i feels A LOT heavier - which seems to contribute to the brake fade.. after 20 minutes into driving, I felt about 60~70% loss. Is it normal for the brake feel to disappear so soon after aggressive driving with the m235i? or is this because my brake pads are probably aged and needs to be replaced? For those who canyon / track / autox, what are your thoughts on the OEM "M" brakes that these cars come in? |
09-04-2019, 06:26 AM | #2 |
Rep 5,577
Yeah the power and weight of car can overwhelm the brakes and many cycles of heating probably effects the pads and fluid.
Chk the braking forum for pad suggestions. |
09-04-2019, 09:45 AM | #3 | |
Rep 3,490
The car is an overpowered tank; it's completely different than the twins.
If you're going to lean on the car, you'd be wise to upgrade both your brake fluid and your brake pads. Quote:
The Anti-Knockback Springs section in this Essex Parts page explains knockback better than I can: https://www.essexparts.com/essex-des...87M2f80M3f82M4.
09-05-2019, 04:07 PM | #4 |
Rep 2,866
Or perhaps just lightly boiled them, and they cooled off? Especially if that is old brake fluid (CPO doesn't always mean they update e/t, just 'check it'). You'll also really work the brakes double time if traction control is on, so the twisties can really heat them up.
09-06-2019, 01:05 AM | #5 | |
Member
Rep 28
Also, when you say 'you work the brakes when the traction is on', does that mean this car's stock diff is brake based? |
09-06-2019, 09:46 AM | #6 | |
Rep 2,866
I would always suspect fluid first, unless it was fairly fresh (it is a very common maintenance item for shops to skip, since almost nobody will care or know how to check it); factory pads also crap out rapidly once they get over their heat range, and I think this should leave visible signs on the pads/rotors (and they wear very fast). The pad knock noted above is also quite possible, but IIRC that will correct almost immediately (just one soft press, then it is fine?). Factory pads aren't great for really heavy duty street or track work, but I'd think it would be hard to overwhelm them on the street (coming down a long steep winding canyon could do it, though). Lately I rely on Zeckhausen for brake advice, you may want to call them for recc's (and good prices) on pads and fluid'; they spent about a half hour with me, and their advice was quite helpful. https://www.zeckhausen.com/catalog/ |
