2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB 2018 M240 Oil Change
      04-12-2018, 08:45 PM   #1
1FUNCAR
1FUNCAR's Avatar
Drives: 2018 M240i Coupe
Does anyone have pics or video of an oil change in an '18 M240? I'm curious about the oil filter location and if it's a knuckle buster to get it out.
aerobod3612.00
      04-13-2018, 06:01 PM   #2
MarcoZandrini
Drives: 2018 M240i
The filter is located on the intake side of the engine, buried under a cover. You’ll need a 32mm shallow 6-point socket and either a wobble end extension or a universal. I used the latter. The top cover has to come off as well as a second black cover between the intake and the electronix. Engine takes 6.5 quarts of oil.
      04-13-2018, 08:59 PM   #3
1FUNCAR
1FUNCAR's Avatar
Originally Posted by MarcoZandrini View Post
The filter is located on the intake side of the engine, buried under a cover. You'll need a 32mm shallow 6-point socket and either a wobble end extension or a universal. I used the latter. The top cover has to come off as well as a second black cover between the intake and the electronix. Engine takes 6.5 quarts of oil.
I've got the universal. I'll have to get a 32mm socket. Sounds fairly easy with the right tools?
      04-14-2018, 09:29 AM   #4
MarcoZandrini
Drives: 2018 M240i
Yup. The socket has to be shallow as there’s not a lot of room between the filter housing cap and the surrounding stuff. Once the cap is loose you can remove it by hand.
1FUNCAR20.50
